| 0004034 | Part | Feature | public | 2019-06-24 22:25 | 2021-02-06 06:46 |
| Reporter | bejant | Assigned To | |||
| Priority | low | Severity | minor | Reproducibility | N/A |
| Platform | 32 bit | OS | Ubuntu | OS Version | 18.04.2 LTS |
| Summary | 0004034: Easier Way to Toggle BOPCheck On / Off | ||||
| Description | Provide an easier method to enable / disable BOPCheck instead of always having to go through Tools > Edit Parameters.  The initial thought was to provide a button or tickbox in the Check Geometry widget but (other than a progress indicator) the Check Geometry widget doesn't appear until after Check Geometry has arrived at the results.  Even though a new user would have to first run Check Geometry before seeing an option for BOPCheck enable / disable, the user would at least be alerted that the option exists, and simultaneously be presented with a simpler way to change the setting. TheMarkster posted in the forum that he had written a tiny macro to quickly and easily enable/disable RunBOPCheck, which gave rise to this feature request. Forum discussion initially started here, and this post includes the macro: https://forum.freecadweb.org/viewtopic.php?f=3&t=37156&start=10#p316228 I later started a discussion for this feature request to avoid further hijacking the original thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=37240 | ||||
| Additional Information | OS: Ubuntu 18.04.2 LTS Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.18.1. Build type: Release Python version: 3.6.7 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
| Tags | UI | ||||
|  | https://github.com/FreeCAD/FreeCAD/pull/2291 |
|  | @TheMarkster FYI, please use the mantisBT syntax to remotely close a MantisBT ticket from a Github PR. And do you mind stating here how the PR addresses this ticket? Thanks. (I'll associate the commit with this ticket manually) |
|  | @TheMarkster, Sorry, let me correct myself, you did try to use the syntax but didn't execute it correctly. You can omit the superflous 0's and just use the number after the pound sign in the future... so either Fixed #(issue number) <-closes or issue #(issue number) <-references |
|  | This ticket has been migrated to GitHub as issue 5953. |
| FreeCAD: master 961ffce9 2019-06-25 01:42:13 Committer: wmayer Details Diff | TaskCheckGeometry settings panel with runBOPCheck option | Affected Issues 0004034 | |
| mod - src/Mod/Part/Gui/TaskCheckGeometry.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/TaskCheckGeometry.h | Diff File | ||
| FreeCAD: master 9a3fe1fb 2019-06-25 19:44:15 Committer: wmayer Details Diff | TaskCheckGeometry -- log geometry check errors to report view | Affected Issues 0004034 | |
| 2019-06-24 22:25 | bejant | New Issue | |
| 2019-06-25 01:59 | TheMarkster | Note Added: 0013306 | |
| 2019-06-25 18:54 | openBrain | Summary | Easier Way to Toggle GOPCheck On / Off => Easier Way to Toggle BOPCheck On / Off |
| 2019-06-25 18:54 | openBrain | Additional Information Updated | |
| 2019-09-30 00:04 | Kunda1 | Tag Attached: UI | |
| 2019-09-30 00:05 | Kunda1 | Target Version | => 0.19 |
| 2019-09-30 00:07 | Kunda1 | Note Added: 0013695 | |
| 2019-09-30 00:10 | Kunda1 | Note Added: 0013696 | |
| 2019-09-30 00:22 | Kunda1 | Changeset attached | => FreeCAD master 961ffce9 |
| 2019-09-30 00:23 | Kunda1 | Changeset attached | => FreeCAD master 9a3fe1fb |
