| 0004036 | Path | Bug | public | 2019-06-25 18:43 | 2021-08-25 17:49 |
| Reporter | freman | Assigned To | |||
| Summary | 0004036: Job | Tool editor does not get keystrokes when mm/s items are selected. | ||||
| Description | when attempting to input cutting speeds into Job edit | Tools tab, keystrokes go to 3D view window and change the view. Annoying and confusing. BTW, these columns do not have meaningful headers. "mm/s" is not the quantity being input, it is the units. User is left to guess which is XY cutting speed and which is Z cutting speed. Space if tight but the unit is not the right text for the header. | ||||
| Steps To Reproduce | create a job set 3D view to isometric go to edit job select tool edit tab click once is one of the "mm/s" text entry boxes note text entry is dark blue indicating it is selected and should recv. keyboard focus type numeric key 6 note 3D view jumps to different view type numeric key 2 note 3D view jumps to different view type numeric key 8 ( out of range of view numbers ) note digit is entered in edit box as expected. Clearly the keyboard events are going initially to the 3D window, it this does not catch the event it is passed to the active editbox. | ||||
| Additional Information | OS: Linux (LXDE/LXDE) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.17119 (Git) Build type: Release Branch: master Hash: e72b48e0cfcf4773e4b6527c74f2bac11ccff1ab Python version: 2.7.15 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) | ||||
