| 0000407 | FreeCAD | Bug | public | 2011-07-25 19:14 | 2011-07-28 07:05 |
| Summary | 0000407: Robot module doesn't compile with Eigen3 | ||||
| Description | Scanning dependencies of target Robot [ 80%] Building CXX object src/Mod/Robot/App/CMakeFiles/Robot.dir/kdl_cp/rotationalinertia.cpp.o /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp: In member function ‘KDL::Vector KDL::RotationalInertia::operator*(const KDL::Vector&) const’: /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp:46: error: invalid conversion from ‘const double*’ to ‘double*’ /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp:46: error: initializing argument 1 of ‘Eigen::Map<MatrixType, MapOptions, StrideType>::Map(typename Eigen::MapBase<Eigen::Map<PlainObjectType, MapOptions, StrideType>, (Eigen::internal::accessors_level::has_write_access ? (Eigen::AccessorLevels)1u : (Eigen::AccessorLevels)0u)>::PointerType, const StrideType&) [with PlainObjectType = Eigen::Matrix<double, 3, 3, 0, 3, 3>, int MapOptions = 0, StrideType = Eigen::Stride<0, 0>]’ /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp:46: error: invalid conversion from ‘const double*’ to ‘double*’ /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp:46: error: initializing argument 1 of ‘Eigen::Map<MatrixType, MapOptions, StrideType>::Map(typename Eigen::MapBase<Eigen::Map<PlainObjectType, MapOptions, StrideType>, (Eigen::internal::accessors_level::has_write_access ? (Eigen::AccessorLevels)1u : (Eigen::AccessorLevels)0u)>::PointerType, const StrideType&) [with PlainObjectType = Eigen::Matrix<double, 3, 1, 0, 3, 1>, int MapOptions = 0, StrideType = Eigen::Stride<0, 0>]’ /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp: In function ‘KDL::RotationalInertia KDL::operator*(double, const KDL::RotationalInertia&)’: /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp:52: error: invalid conversion from ‘const double*’ to ‘double*’ /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp:52: error: initializing argument 1 of ‘Eigen::Map<MatrixType, MapOptions, StrideType>::Map(typename Eigen::MapBase<Eigen::Map<PlainObjectType, MapOptions, StrideType>, (Eigen::internal::accessors_level::has_write_access ? (Eigen::AccessorLevels)1u : (Eigen::AccessorLevels)0u)>::PointerType, const StrideType&) [with PlainObjectType = Eigen::Matrix<double, 3, 3, 0, 3, 3>, int MapOptions = 0, StrideType = Eigen::Stride<0, 0>]’ /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp: In function ‘KDL::RotationalInertia KDL::operator+(const KDL::RotationalInertia&, const KDL::RotationalInertia&)’: /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp:58: error: invalid conversion from ‘const double*’ to ‘double*’ /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp:58: error: initializing argument 1 of ‘Eigen::Map<MatrixType, MapOptions, StrideType>::Map(typename Eigen::MapBase<Eigen::Map<PlainObjectType, MapOptions, StrideType>, (Eigen::internal::accessors_level::has_write_access ? (Eigen::AccessorLevels)1u : (Eigen::AccessorLevels)0u)>::PointerType, const StrideType&) [with PlainObjectType = Eigen::Matrix<double, 3, 3, 0, 3, 3>, int MapOptions = 0, StrideType = Eigen::Stride<0, 0>]’ /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp:58: error: invalid conversion from ‘const double*’ to ‘double*’ /home/werner/Projects/FreeCAD/src/Mod/Robot/App/kdl_cp/rotationalinertia.cpp:58: error: initializing argument 1 of ‘Eigen::Map<MatrixType, MapOptions, StrideType>::Map(typename Eigen::MapBase<Eigen::Map<PlainObjectType, MapOptions, StrideType>, (Eigen::internal::accessors_level::has_write_access ? (Eigen::AccessorLevels)1u : (Eigen::AccessorLevels)0u)>::PointerType, const StrideType&) [with PlainObjectType = Eigen::Matrix<double, 3, 3, 0, 3, 3>, int MapOptions = 0, StrideType = Eigen::Stride<0, 0>]’ make[2]: *** [src/Mod/Robot/App/CMakeFiles/Robot.dir/kdl_cp/rotationalinertia.cpp.o] Fehler 1 make[1]: *** [src/Mod/Robot/App/CMakeFiles/Robot.dir/all] Fehler 2 make: *** [all] Fehler 2 werner@Athene:~/Projects/FreeCAD/_cmake$ | ||||
On Windows it doesn't work either: 1>------ Build started: Project: Robot, Configuration: Debug x64 ------ 1>Compiling... 1>svd_eigen_HH.cpp 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities\svd_eigen_HH.hpp(31) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities\svd_eigen_HH.hpp(70) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities\svd_eigen_HH.hpp(70) : error C2143: syntax error : missing ',' before '&' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(26) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(26) : error C2143: syntax error : missing ',' before '&' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(29) : error C2065: 'A' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(29) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(30) : error C2065: 'A' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(30) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(32) : error C2065: 'U' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(32) : error C2228: left of '.setZero' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(33) : error C2065: 'U' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(33) : error C2228: left of '.corner' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(33) : error C2065: 'A' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(43) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(47) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(48) : error C2065: 'epsilon' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(52) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(53) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(53) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(55) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(59) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(62) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(62) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(66) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(66) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(68) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(72) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(76) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(77) : error C2065: 'epsilon' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(79) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(80) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(80) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(82) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(86) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(88) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(88) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(90) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(90) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(91) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(91) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(93) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(96) : warning C4800: 'double' : forcing value to bool 'true' or 'false' (performance warning) 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(97) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(97) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(103) : error C2065: 'epsilon' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(104) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(105) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(105) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(105) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(107) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(107) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(108) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(108) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(111) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(111) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(113) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(114) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(120) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(121) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(122) : error C2065: 'epsilon' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(125) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(125) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(126) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(127) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(128) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(128) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(130) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(132) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(134) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(139) : error C2065: 'maxiter' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(143) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(147) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(153) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(154) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(154) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(156) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(158) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(164) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(165) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(166) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(167) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(171) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(175) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(176) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(176) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(181) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(183) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(184) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(185) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(198) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(199) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(203) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(212) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(213) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(214) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(215) : error C3861: 'V': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(218) : error C3861: 'S': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(220) : error C2065: 'epsilon' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(228) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(229) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(230) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(231) : error C3861: 'U': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(234) : error C3861: 'tmp': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\utilities\svd_eigen_HH.cpp(234) : fatal error C1003: error count exceeds 100; stopping compilation 1>treeiksolvervel_wdls.cpp 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(17) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(48) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(48) : error C2143: syntax error : missing ',' before '&' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(49) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(49) : error C2143: syntax error : missing ';' before '&' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(49) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(49) : warning C4183: 'getWeightJS': missing return type; assumed to be a member function returning 'int' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(74) : error C2327: 'KDL::TreeIkSolverVel_wdls::MatrixXd' : is not a type name, static, or enumerator 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(74) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(74) : error C2143: syntax error : missing ',' before '&' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(75) : error C2327: 'KDL::TreeIkSolverVel_wdls::MatrixXd' : is not a type name, static, or enumerator 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(75) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(75) : error C2143: syntax error : missing ';' before '&' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(75) : error C2086: 'const int KDL::TreeIkSolverVel_wdls::MatrixXd' : redefinition 1> c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(49) : see declaration of 'KDL::TreeIkSolverVel_wdls::MatrixXd' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(75) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(75) : warning C4183: 'getWeightTS': missing return type; assumed to be a member function returning 'int' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C2327: 'KDL::TreeIkSolverVel_wdls::MatrixXd' : is not a type name, static, or enumerator 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C2146: syntax error : missing ';' before identifier 'J' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(85) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(86) : error C2146: syntax error : missing ';' before identifier 't' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(86) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(86) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(86) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(86) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(86) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(86) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(49) : error C2065: 'Wq' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(75) : error C2065: 'Wy' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_HH.hpp(31) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_HH.hpp(70) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_HH.hpp(70) : error C2143: syntax error : missing ',' before '&' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(16) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(16) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(17) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(17) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(17) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(17) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(17) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(17) : error C3861: 'Identity': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(18) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(18) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(18) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(18) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(18) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(18) : error C3861: 'Identity': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(19) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(19) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(19) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(19) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(19) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(19) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(19) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(19) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(20) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(20) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(20) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(20) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(20) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(20) : error C3861: 'Identity': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(21) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(21) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(21) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(21) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(21) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(21) : error C3861: 'Identity': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(22) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(22) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(22) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(22) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(22) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(22) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(22) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(22) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(23) : error C2653: 'VectorXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(23) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(23) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(23) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(23) : error C2653: 'VectorXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(23) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(23) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(23) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(24) : error C2653: 'VectorXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(24) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(24) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(24) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(25) : error C2653: 'VectorXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(25) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(25) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(25) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(25) : error C2653: 'VectorXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(25) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(25) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(25) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2758: 'KDL::TreeIkSolverVel_wdls::MatrixXd' : must be initialized in constructor base/member initializer list 1> c:\projects\freecad\src\mod\robot\app\kdl_cp\treeiksolvervel_wdls.hpp(49) : see declaration of 'KDL::TreeIkSolverVel_wdls::MatrixXd' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'S' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'tmp' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'qdot' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'Wy_t' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 't' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'Wq_V' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'Wy_U' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'V' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'U' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'Wy_J_Wq' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'J_Wq' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'Wq' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'Wy' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(26) : error C2614: 'KDL::TreeIkSolverVel_wdls' : illegal member initialization: 'J' is not a base or member 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(37) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(37) : error C2143: syntax error : missing ',' before '&' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(38) : error C2065: 'Wq' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(38) : error C2065: 'Mq' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(41) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(41) : error C2143: syntax error : missing ',' before '&' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(42) : error C2065: 'Wy' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(42) : error C2065: 'Mx' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(69) : error C2065: 'J' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(69) : error C2228: left of '.block' must have class/struct/union 1> type is ''unknown-type'' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(71) : error C2065: 't' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(71) : error C2228: left of '.segment' must have class/struct/union 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\treeiksolvervel_wdls.cpp(71) : fatal error C1003: error count exceeds 100; stopping compilation 1>rotationalinertia.cpp 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rotationalinertia.cpp(46) : error C2440: '<function-style-cast>' : cannot convert from 'const double [9]' to 'Eigen::Map<PlainObjectType>' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix3d 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rotationalinertia.cpp(46) : error C2440: '<function-style-cast>' : cannot convert from 'const double [3]' to 'Eigen::Map<PlainObjectType>' 1> with 1> [ 1> PlainObjectType=Eigen::Vector3d 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rotationalinertia.cpp(52) : error C2440: '<function-style-cast>' : cannot convert from 'const double [9]' to 'Eigen::Map<PlainObjectType>' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix3d 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rotationalinertia.cpp(58) : error C2440: '<function-style-cast>' : cannot convert from 'const double [9]' to 'Eigen::Map<PlainObjectType>' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix3d 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rotationalinertia.cpp(58) : error C2440: '<function-style-cast>' : cannot convert from 'const double [9]' to 'Eigen::Map<PlainObjectType>' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix3d 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>rigidbodyinertia.cpp 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rigidbodyinertia.cpp(40) : error C2440: '<function-style-cast>' : cannot convert from 'const double [3]' to 'Eigen::Map<PlainObjectType,MapOptions>' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix<double,3,1>, 1> MapOptions=0 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rigidbodyinertia.cpp(40) : error C2512: 'Eigen::Matrix<_Scalar,_Rows,_Cols>::Matrix' : no appropriate default constructor available 1> with 1> [ 1> _Scalar=double, 1> _Rows=3, 1> _Cols=1 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rigidbodyinertia.cpp(41) : error C2440: '<function-style-cast>' : cannot convert from 'const double [9]' to 'Eigen::Map<PlainObjectType>' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix3d 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rigidbodyinertia.cpp(63) : error C2440: '<function-style-cast>' : cannot convert from 'const double [3]' to 'Eigen::Map<PlainObjectType,MapOptions>' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix<double,3,1>, 1> MapOptions=0 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rigidbodyinertia.cpp(63) : error C2512: 'Eigen::Matrix<_Scalar,_Rows,_Cols>::Matrix' : no appropriate default constructor available 1> with 1> [ 1> _Scalar=double, 1> _Rows=3, 1> _Cols=1 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rigidbodyinertia.cpp(69) : error C2440: '<function-style-cast>' : cannot convert from 'const double [9]' to 'Eigen::Map<PlainObjectType>' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix3d 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rigidbodyinertia.cpp(78) : error C2440: '<function-style-cast>' : cannot convert from 'const double [9]' to 'Eigen::Map<PlainObjectType>' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix3d 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rigidbodyinertia.cpp(78) : error C2512: 'Eigen::Matrix<_Scalar,_Rows,_Cols>::Matrix' : no appropriate default constructor available 1> with 1> [ 1> _Scalar=double, 1> _Rows=3, 1> _Cols=3 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rigidbodyinertia.cpp(80) : error C2440: '<function-style-cast>' : cannot convert from 'const double [9]' to 'Eigen::Map<PlainObjectType>' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix3d 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rigidbodyinertia.cpp(90) : error C2440: '<function-style-cast>' : cannot convert from 'const double [3]' to 'Eigen::Map<PlainObjectType,MapOptions>' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix<double,3,1>, 1> MapOptions=0 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\rigidbodyinertia.cpp(90) : error C2512: 'Eigen::Matrix<_Scalar,_Rows,_Cols>::Matrix' : no appropriate default constructor available 1> with 1> [ 1> _Scalar=double, 1> _Rows=3, 1> _Cols=1 1> ] 1>jntspaceinertiamatrix.cpp 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jntspaceinertiamatrix.cpp(28) : error C2143: syntax error : missing ';' before 'KDL::JntSpaceInertiaMatrix::{ctor}' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jntspaceinertiamatrix.cpp(28) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jntspaceinertiamatrix.cpp(72) : warning C4244: 'return' : conversion from '__int64' to 'unsigned int', possible loss of data 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jntspaceinertiamatrix.cpp(77) : warning C4244: 'return' : conversion from '__int64' to 'unsigned int', possible loss of data 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jntspaceinertiamatrix.cpp(103) : error C2039: 'lazy' : is not a member of 'Eigen::GeneralProduct<Lhs,Rhs,ProductType>' 1> with 1> [ 1> Lhs=Eigen::Matrix<double,-1,-1>, 1> Rhs=Eigen::Matrix<double,-1,1>, 1> ProductType=4 1> ] 1>jntarray.cpp 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jntarray.cpp(28) : error C2143: syntax error : missing ';' before 'KDL::JntArray::{ctor}' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jntarray.cpp(28) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jntarray.cpp(74) : warning C4244: 'return' : conversion from '__int64' to 'unsigned int', possible loss of data 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jntarray.cpp(79) : warning C4244: 'return' : conversion from '__int64' to 'unsigned int', possible loss of data 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jntarray.cpp(104) : error C2039: 'lazy' : is not a member of 'Eigen::CoeffBasedProduct<LhsNested,RhsNested,NestingFlags>' 1> with 1> [ 1> LhsNested=const Eigen::Matrix<double,6,-1> &, 1> RhsNested=const Eigen::Matrix<double,-1,1> &, 1> NestingFlags=6 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jntarray.cpp(104) : error C2512: 'Eigen::Matrix<_Scalar,_Rows,_Cols>::Matrix' : no appropriate default constructor available 1> with 1> [ 1> _Scalar=double, 1> _Rows=6, 1> _Cols=1 1> ] 1>jacobian.cpp 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jacobian.cpp(28) : error C2143: syntax error : missing ';' before 'KDL::Jacobian::{ctor}' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jacobian.cpp(28) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jacobian.cpp(72) : warning C4244: 'return' : conversion from '__int64' to 'unsigned int', possible loss of data 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jacobian.cpp(77) : warning C4244: 'return' : conversion from '__int64' to 'unsigned int', possible loss of data 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jacobian.cpp(150) : error C2039: 'start' : is not a member of 'Eigen::Block<XprType,BlockRows,BlockCols,InnerPanel>' 1> with 1> [ 1> XprType=Eigen::Matrix<double,6,-1>, 1> BlockRows=6, 1> BlockCols=1, 1> InnerPanel=true 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jacobian.cpp(150) : error C2059: syntax error : ')' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jacobian.cpp(150) : error C2065: 'Vector3d' : undeclared identifier 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jacobian.cpp(151) : error C2039: 'end' : is not a member of 'Eigen::Block<XprType,BlockRows,BlockCols,InnerPanel>' 1> with 1> [ 1> XprType=Eigen::Matrix<double,6,-1>, 1> BlockRows=6, 1> BlockCols=1, 1> InnerPanel=true 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jacobian.cpp(151) : error C2059: syntax error : ')' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\jacobian.cpp(151) : error C2065: 'Vector3d' : undeclared identifier 1>chainiksolvervel_wdls.cpp 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_HH.hpp(31) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_HH.hpp(70) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_HH.hpp(70) : error C2143: syntax error : missing ',' before '&' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(32) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(32) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(33) : error C2653: 'VectorXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(33) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(34) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(34) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(37) : error C2653: 'VectorXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(37) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(38) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(38) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(39) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(39) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(40) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(40) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(41) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(41) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(42) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(42) : error C3861: 'Zero': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(43) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(43) : error C3861: 'Identity': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(44) : error C2653: 'MatrixXd' : is not a class or namespace name 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(44) : error C3861: 'Identity': identifier not found 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(81) : error C2039: 'lazy' : is not a member of 'Eigen::GeneralProduct<Lhs,Rhs,ProductType>' 1> with 1> [ 1> Lhs=Eigen::Matrix<double,6,-1>, 1> Rhs=Eigen::Matrix<double,-1,-1>, 1> ProductType=5 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(82) : error C2039: 'lazy' : is not a member of 'Eigen::GeneralProduct<Lhs,Rhs,ProductType>' 1> with 1> [ 1> Lhs=Eigen::Matrix<double,-1,-1>, 1> Rhs=Eigen::Matrix<double,-1,-1>, 1> ProductType=5 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(85) : error C2660: 'KDL::svd_eigen_HH' : function does not take 6 arguments 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(88) : error C2039: 'corner' : is not a member of 'Eigen::Matrix<_Scalar,_Rows,_Cols>' 1> with 1> [ 1> _Scalar=double, 1> _Rows=-1, 1> _Cols=-1 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(88) : error C2228: left of '.lazy' must have class/struct/union 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(89) : error C2039: 'lazy' : is not a member of 'Eigen::GeneralProduct<Lhs,Rhs,ProductType>' 1> with 1> [ 1> Lhs=Eigen::Matrix<double,-1,-1>, 1> Rhs=Eigen::Matrix<double,-1,-1>, 1> ProductType=5 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\chainiksolvervel_wdls.cpp(115) : error C2039: 'lazy' : is not a member of 'Eigen::GeneralProduct<Lhs,Rhs,ProductType>' 1> with 1> [ 1> Lhs=Eigen::Matrix<double,-1,-1>, 1> Rhs=Eigen::Matrix<double,-1,1>, 1> ProductType=4 1> ] 1>chainiksolvervel_pinv_givens.cpp 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(11) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(49) : error C2146: syntax error : missing ';' before identifier 'jac_eigen' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(49) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(49) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(49) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(49) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(49) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(50) : error C2146: syntax error : missing ';' before identifier 'S' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(50) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(50) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(50) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(50) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(50) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(50) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(50) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(50) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(31) : error C2143: syntax error : missing ';' before 'namespace' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(31) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(31) : error C2086: 'int USING_PART_OF_NAMESPACE_EIGEN' : redefinition 1> c:\projects\freecad\src\mod\robot\app\kdl_cp\chainiksolvervel_pinv_givens.hpp(11) : see declaration of 'USING_PART_OF_NAMESPACE_EIGEN' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(33) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(33) : error C2143: syntax error : missing ',' before '&' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(40) : error C2065: 'toggle' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(42) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(42) : error C2065: 'A' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(42) : error C2065: 'V' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(42) : error C2228: left of '.lazy' must have class/struct/union 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(47) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(47) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(48) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(48) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(50) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(50) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(50) : error C2228: left of '.dot' must have class/struct/union 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(50) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(50) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(51) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(51) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(51) : error C2228: left of '.dot' must have class/struct/union 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(51) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(51) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(52) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(52) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(52) : error C2228: left of '.dot' must have class/struct/union 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(52) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(52) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(57) : error C2065: 'treshold' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(74) : error C2065: 'tempi' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(74) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(74) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(74) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(74) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(75) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(75) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(75) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(75) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(75) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(75) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(76) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(76) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(76) : error C2065: 'tempi' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(79) : error C2065: 'tempi' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(79) : error C2228: left of '.start' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(79) : error C2065: 'V' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(79) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(79) : error C2065: 'V' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(79) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(79) : error C2065: 'V' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(79) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(80) : error C2065: 'V' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(80) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(80) : error C2065: 'V' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(80) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(80) : error C2065: 'V' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(80) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(81) : error C2065: 'V' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(81) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(81) : error C2065: 'tempi' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(81) : error C2228: left of '.start' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(81) : error C2065: 'V' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(81) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(88) : error C2065: 'U' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(88) : error C2228: left of '.rows' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(89) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(89) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(90) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(90) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(90) : error C2228: left of '.dot' must have class/struct/union 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(90) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(90) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(92) : error C2065: 'U' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(92) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(92) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(92) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(94) : error C2065: 'U' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(94) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(94) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(94) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(95) : error C3861: 'S': identifier not found 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(98) : error C2065: 'U' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(98) : error C2228: left of '.col' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(98) : error C2065: 'tempi' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(106) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(106) : error C2065: 'U' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(106) : error C2228: left of '.transpose' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(106) : error C2065: 'A' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(106) : error C2228: left of '.lazy' must have class/struct/union 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(111) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(111) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(112) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(112) : error C2228: left of '.cols' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(114) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(114) : error C2228: left of '.row' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(114) : error C2228: left of '.dot' must have class/struct/union 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(114) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(114) : error C2228: left of '.row' must have class/struct/union 1> type is ''unknown-type'' 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(115) : error C2065: 'B' : undeclared identifier 1>c:\projects\freecad\src\mod\robot\app\kdl_cp\utilities/svd_eigen_Macie.hpp(115) : fatal error C1003: error count exceeds 100; stopping compilation 1>articulatedbodyinertia.cpp 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\articulatedbodyinertia.cpp(32) : error C2039: 'part' : is not a member of 'Eigen::Matrix<_Scalar,_Rows,_Cols>' 1> with 1> [ 1> _Scalar=double, 1> _Rows=3, 1> _Cols=3 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\articulatedbodyinertia.cpp(32) : error C2059: syntax error : ')' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\articulatedbodyinertia.cpp(33) : error C2039: 'part' : is not a member of 'Eigen::Matrix<_Scalar,_Rows,_Cols>' 1> with 1> [ 1> _Scalar=double, 1> _Rows=3, 1> _Cols=3 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\articulatedbodyinertia.cpp(33) : error C2059: syntax error : ')' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\articulatedbodyinertia.cpp(46) : error C2039: 'part' : is not a member of 'Eigen::Matrix<_Scalar,_Rows,_Cols>' 1> with 1> [ 1> _Scalar=double, 1> _Rows=3, 1> _Cols=3 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\articulatedbodyinertia.cpp(46) : error C2059: syntax error : ')' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\articulatedbodyinertia.cpp(47) : error C2039: 'part' : is not a member of 'Eigen::Matrix<_Scalar,_Rows,_Cols>' 1> with 1> [ 1> _Scalar=double, 1> _Rows=3, 1> _Cols=3 1> ] 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\articulatedbodyinertia.cpp(47) : error C2059: syntax error : ')' 1>..\..\..\..\..\src\Mod\Robot\App\kdl_cp\articulatedbodyinertia.cpp(93) : error C2664: 'Eigen::Map<PlainObjectType,MapOptions>::Map(double *,const StrideType &)' : cannot convert parameter 1 from 'const double [9]' to 'double *' 1> with 1> [ 1> PlainObjectType=Eigen::Matrix<double,3,3>, 1> MapOptions=0, 1> StrideType=Eigen::Stride<0,0> 1> ] 1> Conversion loses qualifiers 1>Generating Code... 1>Build log was saved at "file://c:\Projects\FreeCAD\x64\src\Mod\Robot\App\Robot.dir\Debug\BuildLog.htm" 1>Robot - 421 error(s), 9 warning(s) 2>------ Skipped Build: Project: INSTALL, Configuration: Debug x64 ------ 2>Project not selected to build for this solution configuration ========== Build: 0 succeeded, 1 failed, 49 up-to-date, 1 skipped ========== |
According to [1] setting the define EIGEN2_SUPPORT fixes the build errors. [1] http://eigen.tuxfamily.org/dox/Eigen2ToEigen3.html |
Fixed by setting EIGEN2_SUPPORT |
| 2011-07-25 19:14 | wmayer | New Issue | |
| 2011-07-25 19:14 | wmayer | Assigned To | => Jriegel |
| 2011-07-25 19:14 | wmayer | Status | new => assigned |
| 2011-07-26 11:18 | wmayer | Note Added: 0000945 | |
| 2011-07-26 11:38 | wmayer | Note Added: 0000947 | |
| 2011-07-28 07:05 | wmayer | Note Added: 0000952 | |
| 2011-07-28 07:05 | wmayer | Status | assigned => closed |
| 2011-07-28 07:05 | wmayer | Resolution | open => fixed |
| 2011-07-28 07:05 | wmayer | Fixed in Version | => 0.12 |
