| 0004101 | Part | Bug | public | 2019-08-27 18:07 | 2019-08-28 18:09 |
| Reporter | pkoning2 | Assigned To | |||
| Summary | 0004101: Face with list of wires for face with holes no longer works | ||||
| Description | As of version 0.17, Part.Face([wire,wire2,...]) no longer works. It used to produce a face with holes in it, and is documented to do that. Currently it produces a face consisting of one of the wires, with the other wire(s) only outlined. | ||||
| Steps To Reproduce | The following test will show the issue: from FreeCAD import Base import Part V=Base.Vector t1=Part.makePolygon([V(0,0,0), V(10,0,0), V(0,10,0),V(0,0,0)]) t2=Part.makePolygon([V(-10,-10,0), V(20,0,0), V(0,20,0),V(-10,-10,0)]) f3=Part.Face([t2,t1]) Part.show(f3) In version 0.16 I get a triangle (t2) with a triangular hole in it (t1), as documented. In 0.17, 0.18, or 0.19dev, I get t1 shown as a face, surrounded by t2 just as an outline. I'll try using intersections as an alternate way to make holes in parts, but this issue broke an existing (Python based) model I have been working on for some time. | ||||
| Tags | #post-to-forum | ||||
@pkoning2 : thanks for reporting. However, according guidelines (big yellow banner), could you please first open a forum topic (Python subforum) so the community can help validate and identify ? Thanks |
That seems like a lot of extra work for such a simple thing, but ok, done. https://forum.freecadweb.org/viewtopic.php?f=22&t=38881 |
From the forum I learn that this is a documentation problem. There is a magic workaround for the incorrect handling of wire direction in the underlying machinery. Since it's a Wiki I guess I can fix the documentation gap. |
Due to OCC changes. Solution exists. Eventually lack some documentation. Cf. forum thread. Closed as is. |
| 2019-08-27 18:07 | pkoning2 | New Issue | |
| 2019-08-27 18:41 | openBrain | Note Added: 0013470 | |
| 2019-08-27 18:41 | openBrain | Tag Attached: #post-to-forum | |
| 2019-08-27 18:42 | openBrain | Status | new => feedback |
| 2019-08-27 18:56 | pkoning2 | Note Added: 0013473 | |
| 2019-08-27 18:56 | pkoning2 | Status | feedback => new |
| 2019-08-27 20:43 | pkoning2 | Note Added: 0013474 | |
| 2019-08-28 18:09 | openBrain | Status | new => closed |
| 2019-08-28 18:09 | openBrain | Resolution | open => no change required |
| 2019-08-28 18:09 | openBrain | Note Added: 0013478 |
