| 0004111 | Path | Bug | public | 2019-09-02 06:52 | 2020-10-16 16:57 |
| Reporter | freman | Assigned To | russ4262 | ||
| Summary | 0004111: inconsistent cut direction in 3Dsurface | ||||
| Description | https://forum.freecadweb.org/viewtopic.php?f=15&t=39016 | ||||
| Steps To Reproduce | Make a 3d model select a non planar face create a 3Dsurface path note alternating direction of cutting paths. eg increasing X then decreasing X. Choice of cutting convention is a basic machining requirement, not an optional extra. There really needs to be some way to control this. The current alternating paths will be undesirable for most applications, be it wood, metal or whatever. | ||||
| Additional Information | OS: Linux (LXDE/LXDE) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.16988 (Git) Build type: Unknown Branch: master Hash: ff7975291d33a88e6a8282b88a62dbcbcc01ba2b Python version: 2.7.15 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) | ||||
This appears to be resolved by an earlier PR. I can't find the specific one but have tested with current build and 'line' pattern produces unidirectional gcode. Thanks Russ! |
| 2019-09-02 06:52 | freman | New Issue | |
| 2019-09-02 06:52 | freman | File Added: 3Dsurface-detail.jpeg | |
| 2020-10-16 16:56 | sliptonic | Assigned To | => russ4262 |
| 2020-10-16 16:56 | sliptonic | Status | new => assigned |
| 2020-10-16 16:57 | sliptonic | Status | assigned => closed |
| 2020-10-16 16:57 | sliptonic | Resolution | open => fixed |
| 2020-10-16 16:57 | sliptonic | Note Added: 0014890 |
