| 0000412 | FreeCAD | Bug | public | 2011-08-02 05:21 | 2011-08-03 05:00 |
| Summary | 0000412: special characters in annotation corrupt file | ||||
| Description | When you use a special character (in my case the German umlauts Ä Ö Ü, hope you can see those) in an Annotation the are displayed perfect. However when you save and reopen the file appear incomplete or an exception occurs. | ||||
| Additional Information | To reproduce: 1) Start with a blank file. 2) Create an annotation with label text [Munich] 3) Save file and reopen => no problem. 4) Alter label text to [München] 5) Save file and reopen => project tree appears empty | ||||
2011-08-02 05:21
When trying to load the above file FreeCAD even crashes and also when I try to write "München" the 'ü' is missing because the OpenInventor library doesn't support this. With which version of FreeCAD and under what platform did you create the file? |
This bug has been fixed in 0.12 for a couple of weeks. The problem there was the wrong encoding (ISO 8859-1) was used to write out XML data. When reading in it was assumed that everything is in UTF-8 but due to the wrong encoding some forbidden characters has been written out. |
Fixed sometime in an earlier revision. |
| 2011-08-02 05:21 | unauthenticated | New Issue | |
| 2011-08-02 05:21 | unauthenticated | File Added: test_ÄÖÜ.FCStd | |
| 2011-08-02 06:20 | wmayer | Note Added: 0000970 | |
| 2011-08-02 09:31 | wmayer | Note Added: 0000971 | |
| 2011-08-03 05:00 | wmayer | Note Added: 0000972 | |
| 2011-08-03 05:00 | wmayer | Status | new => closed |
| 2011-08-03 05:00 | wmayer | Resolution | open => no change required |
| 2011-08-03 05:00 | wmayer | Fixed in Version | => 0.12 |
