| 0000416 | Sketcher | Bug | public | 2011-08-13 09:16 | 2016-01-08 16:14 |
| Reporter | mrlukeparry | Assigned To | abdullah | ||
| Summary | 0000416: Sketcher: Slow Solving Peformance when adding unconstrainted arcs to Sketch | ||||
| Description | Just raise an issue in the solver with performance in solver: If you add many (e.g. 10) arcs. The solver takes very longer the sketch - even without any constraints. I find it may take 0.005s to solve on my machine. This delay clearly shows when dragging any other point such as line. I have noticed this doesn't happen when adding many lines or circle geometries to the sketch. It should be reproducible all the time. Its perhaps worth an investigation. | ||||
| Additional Information | Latest Revision from SVN CPU - Quad Core Memory 3gb | ||||
| 2011-08-13 09:16 | mrlukeparry | New Issue | |
| 2011-08-14 17:19 |
Status | new => assigned |
| 2011-08-14 17:19 |
Assigned To | => logari81 |
| 2011-11-03 17:29 | logari81 | Product Version | trunk => |
| 2011-11-03 17:29 | logari81 | Summary | Sketcher Module: Slow Solving Peformance when adding unconstrainted arcs to Sketch => Sketcher: Slow Solving Peformance when adding unconstrainted arcs to Sketch |
| 2012-04-13 19:40 | logari81 | Note Added: 0001943 | |
| 2012-05-05 17:50 | yorik | Project | FreeCAD => Sketcher |
| 2016-01-08 16:13 | abdullah | Assigned To | logari81 => abdullah |
| 2016-01-08 16:14 | abdullah | Note Added: 0006691 | |
| 2016-01-08 16:14 | abdullah | Status | assigned => closed |
| 2016-01-08 16:14 | abdullah | Resolution | open => fixed |
| 2016-01-08 16:14 | abdullah | Fixed in Version | => 0.16 |
