| 0000418 | FreeCAD | Bug | public | 2011-08-17 07:10 | 2011-08-19 12:06 |
| Summary | 0000418: Sketcher - When pading I get unclosed shape | ||||
| Description | Hi, This one is easy to reproduce Place two arcs so that they have center at the same point - use coincidence on their center Then place two lines so that the shape gets to be closed - use coincidence between lines and arcs you can see the shape you get when you pad this | ||||
| Additional Information | freecad build 4725 win7 32bit | ||||
2011-08-17 07:10
Using arcs leads to an error somewhere in the model. Calling the check() method of the resulting solid shows the error message that a few faces are unorientable. But e.g. with fix(0.0001,0.0001,0.0001) the solid is repaired and shows the missing faces. |
I have tested other arcs, and the problem appears only if two arcs have coincidence constraint in centers. other cases do not post this issue. Regards Petar |
Here is an example which also fails with two not-coincident arc centers: http://forum.freecadweb.org/viewtopic.php?f=8&t=1205&start=20 |
Fixed in r4771 |
| 2011-08-17 07:10 | pperisin | New Issue | |
| 2011-08-17 07:10 | pperisin | File Added: pad.png | |
| 2011-08-17 09:10 | wmayer | Note Added: 0000980 | |
| 2011-08-17 13:02 | pperisin | Note Added: 0000983 | |
| 2011-08-19 07:12 | unauthenticated | Note Added: 0000987 | |
| 2011-08-19 12:06 | wmayer | Note Added: 0000988 | |
| 2011-08-19 12:06 | wmayer | Status | new => closed |
| 2011-08-19 12:06 | wmayer | Resolution | open => fixed |
| 2011-08-19 12:06 | wmayer | Fixed in Version | => 0.12 |
