| 0004211 | PartDesign | Bug | public | 2019-12-05 06:04 | 2021-02-06 06:43 |
| Reporter | Dan-K | Assigned To | |||
| OS | Windows 10, macOS Catalina | OS Version | 1607, 10.15.1 | ||
| Summary | 0004211: PartDesign Pad 'Up to face' has issues when selecting a ShapeBinder's or Binder's face | ||||
| Description | If a PartDesign body has a ShapeBinder or Binder to a reference object and a sketch within that same body attempts to pad to once of the binder's surfaces with 'Up to face', the following error occurs:
Discussed on the forum: https://forum.freecad.org/viewtopic.php?f=3&t=41280 | ||||
| Steps To Reproduce | 1. Download and open the attached 'uptoface-bug.FCStd' file. 2. Notice the 'Target Body' PartDesign Body has a ShapeBinder and a Binder of the 'Static Body' body and that the positions of these binders are correct. 3. Hide the 'Static Body' and one of the binder objects such that the other binder object is visible. 4. Switch to the 'PartDesign' workbench. 5. Select 'Sketch002' from the tree. 6. Press the 'PartDesign' 'Pad' button. 7. Change the 'Type' to 'Up to face'. 8. Select one of the two faces of the visible binder object whose normal is parallel to the sketch's face. 9. Press 'OK'. 10. Notice the error popup and error message in the 'Report view'. 11. This can be repeated with the other binder object, the issue will happen with both ShapeBinder and Binder. | ||||
| Tags | 0.18, 0.19, shapebinder | ||||
| FreeCAD Information | OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18811 (Git) Build type: Release Branch: master Hash: b809867021deb37be1039dab37b9fe1cafab254e Python version: 3.6.7 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/Canada (en_CA) | ||||
| 2019-12-05 06:04 | Dan-K | New Issue | |
| 2019-12-05 06:04 | Dan-K | Tag Attached: 0.18 | |
| 2019-12-05 06:04 | Dan-K | Tag Attached: 0.19 | |
| 2019-12-05 06:04 | Dan-K | Tag Attached: Part Design | |
| 2019-12-05 06:04 | Dan-K | Tag Attached: shapebinder | |
| 2019-12-05 06:04 | Dan-K | File Added: uptoface-bug.FCStd | |
| 2019-12-05 06:06 | Dan-K | Description Updated | |
| 2019-12-05 06:06 | Dan-K | Steps to Reproduce Updated | |
| 2019-12-05 06:06 | Dan-K | FreeCAD Information | OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18811 (Git) Build type: Release Branch: master Hash: b809867021deb37be1039dab37b9fe1cafab254e Python version: 3.6.7 Qt version: 5.12.1 Coin version: 4.0.0a OCC ver... => OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18811 (Git) Build type: Release Branch: master Hash: b809867021deb37be1039dab37b9fe1cafab254e Python version: 3.6.7 Qt version: 5.12.1 Coin version: 4.0.0... |
| 2019-12-05 07:16 | Dan-K | Steps to Reproduce Updated | |
| 2019-12-05 12:26 | openBrain | Tag Detached: Part Design | |
