| 0004218 | FreeCAD | Bug | public | 2019-12-06 10:30 | 2019-12-06 10:49 |
| Reporter | laidback3d | Assigned To | |||
| Summary | 0004218: Using division sign in measurement constraint | ||||
| Description | Using division in the dimension constraint doesn't work if "mm" is in the text field. All other operators work, + - *. Only way to make dividision(/) work is to remove the "mm" from the text entry | ||||
| Steps To Reproduce | It's reproducible in any file. Open up the dimension constraint and try any number with /, without removing the default mm entry. | ||||
| FreeCAD Information | OS: Linux Mint 19.2 (X-Cinnamon/cinnamon) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18829 (Git) AppImage Build type: Release Branch: master Hash: 186d52ffd47696fadcd91369365e97f084051e7b Python version: 3.7.3 Qt version: 5.12.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United States (en_US) | ||||
| duplicate of | 0004196 | confirmed | Expressions | Expression parser does not allow "/" after first member |
@laidback3d : per the guidelines in the huge yellow banner, you should have :
| 2019-12-06 10:30 | laidback3d | New Issue | |
| 2019-12-06 10:48 | openBrain | Relationship added | duplicate of 0004196 |
| 2019-12-06 10:49 | openBrain | Status | new => closed |
| 2019-12-06 10:49 | openBrain | Resolution | open => duplicate |
| 2019-12-06 10:49 | openBrain | Note Added: 0013876 |
