| 0000422 | FreeCAD | Bug | public | 2011-08-23 12:25 | 2011-09-28 20:31 |
| Summary | 0000422: Sketcher inverts horizontal and vertical constraints in YZ plane | ||||
| Description | Hi, Sketcher inverts horizontal and vertical constraints in YZ plane Regards Petar | ||||
| Additional Information | Create box select one of it's YZ sides Create new sketch place line select line add horizontal constraint to it | ||||
2011-08-23 12:50
It is also issue with "Fix horizontal distance" and "fix vertical distance" look at the file - although in sketch this shape is on the left side of z axis, when you close it one part of it crosses z axis. |
also, couple of more issues with this file create a pad from this file and the open sketch for editing again. you will see where the pad is and where the sketch is Regards Petar |
I think this is not about the constraints, its about the calculating of the sketch base system.... |
Yeah. The axis are incorrectly orientated. You'll notice that the constraints are correct relative to coordinates. its may be nice to look at fixing when we get reference geometries |
Its only a problem of view direction, if you rotate the view 90 deg alls fine! |
Not a bug, maybe a inconvenience with the standard view directions. |
Set to closed. |
http://forum.freecad.org/viewtopic.php?f=10&t=1393#p10546 shows the steps how to reproduce it |
Fixed with r4979 |
| 2011-08-23 12:25 | pperisin | New Issue | |
| 2011-08-23 12:50 | pperisin | File Added: sketch.FCStd | |
| 2011-08-23 12:52 | pperisin | Note Added: 0000992 | |
| 2011-08-23 13:10 | pperisin | Note Added: 0000993 | |
| 2011-08-24 13:44 |
Note Added: 0000995 | |
| 2011-09-08 17:22 | mrlukeparry | Note Added: 0001052 | |
| 2011-09-16 04:04 |
Note Added: 0001076 | |
| 2011-09-16 04:05 |
Note Added: 0001077 | |
| 2011-09-16 04:05 |
Status | new => resolved |
| 2011-09-16 04:05 |
Resolution | open => fixed |
| 2011-09-16 04:05 |
Assigned To | => Jriegel |
| 2011-09-16 04:06 |
Resolution | fixed => no change required |
| 2011-09-17 06:27 | wmayer | Note Added: 0001103 | |
| 2011-09-17 06:27 | wmayer | Status | resolved => closed |
| 2011-09-26 15:02 | wmayer | Note Added: 0001133 | |
| 2011-09-26 15:02 | wmayer | Status | closed => confirmed |
| 2011-09-26 15:02 | wmayer | Resolution | no change required => reopened |
| 2011-09-26 15:02 | wmayer | Product Version | trunk => |
| 2011-09-28 20:31 | wmayer | Note Added: 0001136 | |
| 2011-09-28 20:31 | wmayer | Status | confirmed => closed |
| 2011-09-28 20:31 | wmayer | Resolution | reopened => fixed |
| 2011-09-28 20:31 | wmayer | Fixed in Version | => 0.12 |
