| 0000425 | FreeCAD | Bug | public | 2011-08-26 07:38 | 2011-12-25 14:20 |
| Reporter | galou_breizh | Assigned To | logari81 | ||
| Summary | 0000425: Sketcher: line-on-point constraint freeze | ||||
| Description | FreeCAD freezes when moving a line to which a point is constrained with point-on-line constraint. | ||||
| Additional Information | latest Ubuntu PPA | ||||
Could you provide more information please. Can you give the exact steps to reproduce this crash? Also are there any error messages? |
- Create a new sketch - create a line - create a second line - select one point of the second line and the first line - add constraint "Fix a point onto an object - move the line --> freeze (no error message) also freezes when: - moving the constrained point - the constrained point is on the line but not on the segment, i.e. not between the two points of the first line |
CPU = 100% when frozen |
With the latest SVN revision I can't reproduce this. But I know we had similar cases in the recent past. So, good possible that this is fixed now. Just wait for the next PPA version and re-check. |
Yesterday night I tested the PPA version where I could see the freeze but the latest SVN build seems to fix it. |
Launchpad 4471 (2011-08-29) still has the problem but in some cases there is no freeze: - move the line by clicking somewhere between its two endpoints (reproducible) - moving the constrained point (sometimes freecad freezes sometimes it doesn't). |
The problem could be in: int System::solve(SubSystem *subsysA, SubSystem *subsysB, int isFine) Having a similar case the for loop iterates until it reaches maxIterNumber but then by a little movement System::solve is called again. |
sorry I couldn't reproduce it on my system so far. |
I have the feeling that this freeze only happens with the PPA version but not we locally compiled versions. Also a locally built debian package works nice. So, there might be something weird with the PPA package. |
Solved in PPA version 4963 (Launchpad). |
| 2011-08-26 07:38 | galou_breizh | New Issue | |
| 2011-08-26 08:17 | mrlukeparry | Note Added: 0001004 | |
| 2011-08-26 09:34 | galou_breizh | Note Added: 0001005 | |
| 2011-08-26 09:34 | galou_breizh | Note Added: 0001006 | |
| 2011-08-26 14:40 | wmayer | Note Added: 0001007 | |
| 2011-08-27 08:31 | wmayer | Note Added: 0001011 | |
| 2011-08-29 05:27 | galou_breizh | Note Added: 0001014 | |
| 2011-08-30 13:41 | wmayer | Note Added: 0001017 | |
| 2011-08-30 13:42 | wmayer | Status | new => assigned |
| 2011-08-30 13:42 | wmayer | Assigned To | => logari81 |
| 2011-08-30 14:01 | logari81 | Note Added: 0001018 | |
| 2011-11-03 17:29 | logari81 | Product Version | trunk => |
| 2011-11-03 17:29 | logari81 | Summary | line-on-point constraint freeze => Sketcher: line-on-point constraint freeze |
| 2011-11-05 23:09 | wmayer | Note Added: 0001261 | |
| 2011-12-19 08:54 | galou_breizh | Note Added: 0001491 | |
| 2011-12-19 08:54 | galou_breizh | Note Edited: 0001491 | |
| 2011-12-19 09:41 | logari81 | Status | assigned => closed |
| 2011-12-19 09:41 | logari81 | Resolution | open => fixed |
| 2011-12-19 09:41 | logari81 | Fixed in Version | => trunk |
| 2011-12-25 14:20 | yorik | Fixed in Version | trunk => 0.13 |
