| 0004292 | Sketcher | Bug | public | 2020-03-20 13:52 | 2021-02-06 05:55 |
| Summary | 0004292: Dimension values are displayed from reverse | ||||
| Description | See the file attached to forum discussion. Double clicking on "Hole Base" shows the numbers from behind. This vanishes as soon as something is changed in the sketch, e.g. a dimension is added. But will reoccur on close/reopen Note that the sketches do not belong to the body. The phenomenon vanishes if the loft is deleted and the sketches are shown in the tree on top level again. | ||||
| FreeCAD Information | OS: macOS High Sierra (10.13) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.20052 (Git) Build type: Release Branch: master Hash: 6291921e9abe737e4440ff5814ca58547defadef Python version: 3.8.2 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
Here is another one. It is again a sketch used for a feature inside of the body, while the sketch lives outside. |
Here is a second file with the same issue. https://forum.freecad.org/viewtopic.php?p=380205#p380152 The issue does not happen in 0.18.4 but does happen in 0.19. OS: Ubuntu 19.10 (ubuntu:GNOME/ubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Python version: 3.7.3 Qt version: 5.12.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United States (en_US) |
The Sketch is inside the Body at least looking from the Model view. The Dependency graph tells a different story. The revolution is inside the Body and the Sketch is outside of it (does not represent what the Model menu shows) However, version FreeCad 0.18.4 interprets the Sketch correctly and the 0.19 shows the values mirrored. |
This ticket has been migrated to GitHub as issue 6040. |
| 2020-03-20 13:52 | chrisb | New Issue | |
| 2020-03-20 13:52 | chrisb | Status | new => assigned |
| 2020-03-20 13:52 | chrisb | Assigned To | => abdullah |
| 2020-03-25 06:14 | chrisb | Note Added: 0014288 | |
| 2020-03-25 16:12 | leoheck | Note Added: 0014289 | |
| 2020-03-25 16:18 | leoheck | Note Added: 0014290 | |
| 2020-11-09 18:06 | abdullah | Target Version | => 0.20 |
| 2021-02-06 05:55 | abdullah | Target Version | => 0.20 |
