| 0004294 | FreeCAD | Feature | public | 2020-03-24 11:20 | 2020-03-26 11:33 |
| Reporter | keithsloan52 | Assigned To | keithsloan52 | ||
| Summary | 0004294: Non Gui functions for creating STEP files only support a flat structure. | ||||
| Description | Trying to code a standalone utility to convert GDML to STEP. Under Gui can use ImportGui.export and this works, but this will not work without the Gui. There are a number of other methods for creating a STEP file but these all take a single list as a parameter for the objects to be exported. This is clearly a problem if one is trying to export a FreeCAD document that has a structure seeYour text to link here... and [url=https://forum.freecadweb.org/viewtopic.php?f=3&t=39351] | ||||
| FreeCAD Information | OS: Ubuntu 18.04.4 LTS (ubuntu:GNOME/ubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Python version: 3.6.9 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) | ||||
Found that Import.export does export non flat structure. (Where as Part will only export flat structure) |
| 2020-03-24 11:20 | keithsloan52 | New Issue | |
| 2020-03-26 11:33 | keithsloan52 | Note Added: 0014292 | |
| 2020-03-26 11:33 | keithsloan52 | Assigned To | => keithsloan52 |
| 2020-03-26 11:33 | keithsloan52 | Status | new => closed |
| 2020-03-26 11:33 | keithsloan52 | Resolution | open => no change required |
