| 0004298 | Expressions | Feature | public | 2020-03-29 18:22 | 2020-05-09 22:55 |
| Reporter | mghansen256 | Assigned To | wmayer | ||
| Summary | 0004298: Feature request: Preserve current value of property when converting to expression | ||||
| Description | It would be nice if property values were automatically transferred into the expression input field when the property is converted into an expression. | ||||
| Steps To Reproduce | 1. Start FreeCAD, create a new document, create a cube 2. Manually move cube to any position, for example (x=1,y=1,z=1) 3. Select the Placement.Position.x property and press "=" to convert it to an expression. Result: The expression input field is empty. If you want to base your expression on the previously set value, you have to type it in again. Expected result as per this feature request: The expression input field is pre-populated with the current value of the property and that part of the text is selected. You can press any key to start writing a new expression from scratch, or press "End" in order to append to the existing value. | ||||
| Additional Information | Related forum thread: Feature request: Preserve current value of property when converting to expression | ||||
| FreeCAD Information | OS: Ubuntu 18.04.1 LTS (KDE/plasma) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.20209 (Git) AppImage Build type: Release Branch: master Hash: 5fc4a26a00390e91cbf91848b766b68ad87e5917 Python version: 3.8.2 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: English/United States (en_US) | ||||
FreeCAD: master ba4d70e7 2020-04-07 19:20:23 0penBrain Committer: wmayer Details Diff |
[Expression] Default to current 'constant' value when editing if no expression set yet ; fixes 0004298 Move signals connecting before value initialization so it's not needed to call them manually Only spin boxes implemented (should be the major usage) |
Affected Issues 0004298 |
| mod - src/Gui/DlgExpressionInput.cpp | Diff File | ||
| 2020-03-29 18:22 | mghansen256 | New Issue | |
| 2020-04-07 19:32 | openBrain | Assigned To | => openBrain |
| 2020-04-07 19:32 | openBrain | Status | new => assigned |
| 2020-04-07 19:32 | openBrain | Note Added: 0014331 | |
| 2020-05-09 09:29 | wmayer | Status | assigned => closed |
| 2020-05-09 09:29 | wmayer | Resolution | open => fixed |
| 2020-05-09 09:29 | wmayer | Fixed in Version | => 0.19 |
| 2020-05-09 09:29 | wmayer | Note Added: 0014405 | |
| 2020-05-09 22:55 | wmayer | Changeset attached | => FreeCAD master ba4d70e7 |
| 2020-05-09 22:55 | wmayer | Note Added: 0014406 | |
| 2020-05-09 22:55 | wmayer | Assigned To | openBrain => wmayer |
