| 0000043 | FreeCAD | Bug | public | 2009-11-18 17:11 | 2009-12-14 08:35 |
| Priority | high | Severity | major | Reproducibility | sometimes |
| Platform | Windows | OS | Windows | OS Version | Vista |
| Target Version | 0.10 | Fixed in Version | 0.9 | ||
| Summary | 0000043: Crash with VC9 builds | ||||
| Description | It seems that the crashes are related to SoQt which is used in version 1.5.0 in the LibPack. There is a special thread class SoQtSignalThread which seems to cause the crashes. Actually, there is no major reason not to use SoQt 1.4.1 which is heavily tested and doesn't seem to cause the crashes. There is only a minor issue when building the libs together with Coin 3.1: in the file SoQtComponent.cpp in line 103 the "unsigned long" must be replaced with "SbDictKeyType" -- that's all. BTW, SoQt 1.5.0 is still not officially released which may be an indication that it's not considered as stable enough. The last official release is SoQt 1.4.1. | ||||
| 2009-11-18 17:11 | wmayer | New Issue | |
| 2009-11-18 17:11 | wmayer | Status | new => assigned |
| 2009-11-18 17:11 | wmayer | Assigned To | => Jriegel |
| 2009-12-06 06:37 |
Note Added: 0000043 | |
| 2009-12-06 06:38 |
Note Added: 0000044 | |
| 2009-12-06 06:38 |
Status | assigned => resolved |
| 2009-12-06 06:38 |
Fixed in Version | => 0.9 |
| 2009-12-06 06:38 |
Resolution | open => fixed |
| 2009-12-14 08:35 | wmayer | Status | resolved => closed |
