| 0004304 | PartDesign | Bug | public | 2020-04-06 15:28 | 2020-05-26 07:46 |
| Reporter | chrisb | Assigned To | openBrain | ||
| Summary | 0004304: Remove "Set Tip" from Body context menu | ||||
| Description | If "Set Tip" is selected from the Body context menu, either in the tree or in the 3D view, the Tip is removed leaving the body without any tip. To avoid cumbersome results the entry should be removed from the menus. Note: this holds only for the body itself, not for the features contained in it. Forum discussion. | ||||
| FreeCAD Information | OS: macOS High Sierra (10.13) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.20209 (Git) Build type: Release Branch: master Hash: 5fc4a26a00390e91cbf91848b766b68ad87e5917 Python version: 3.8.2 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
| 2020-04-06 15:28 | chrisb | New Issue | |
| 2020-04-07 12:21 | openBrain | Assigned To | => openBrain |
| 2020-04-07 12:21 | openBrain | Status | new => assigned |
| 2020-04-07 15:03 | openBrain | Note Added: 0014327 | |
| 2020-04-12 17:31 | Changeset attached | => FreeCAD master f9fc9604 | |
| 2020-04-12 17:31 | guest | Note Added: 0014339 | |
| 2020-05-26 07:46 | openBrain | Status | assigned => closed |
| 2020-05-26 07:46 | openBrain | Resolution | open => fixed |
