0004312FreeCADBugpublic2020-04-13 09:23
Reporterudosoft Assigned To
PrioritynormalSeverityfeatureReproducibilityalways
Product Version0.18
Summary0004312: Fusion does not work with correctly with Array, only Array showed
DescriptionFusion does not work with correctly with Array, only Array showed afterwards, please check attached file
Steps To Reproduceopen attached file
FreeCAD Information<!--ATTENTION:
COMPLETELY ERASE THIS AFTER PASTING YOUR
Help > About FreeCAD > Copy to clipboard
NOTE: just the snippet alone will do without anything else included.
The ticket will not be submitted without it.
udosoft
2020-04-12 13:16
reporter
openBrain
2020-04-13 09:23
developer   ~0014341
@udosoft : when encountering issue with FreeCAD, please process according our reporting guidelines by first opening a topic in our forum.
Especially here there is no bug at all. Just your array isn't fused which messes up the subsequent fusion (set 'Fuse' property of Array to true). Closing
2020-04-12 13:16 udosoft New Issue
2020-04-12 13:16 udosoft File Added: FreeCADbug_makeFusion.FCStd
2020-04-13 09:23 openBrain Severity major => feature
2020-04-13 09:23 openBrain Status new => closed
2020-04-13 09:23 openBrain Resolution open => no change required
2020-04-13 09:23 openBrain Note Added: 0014341
