0004323 | FreeCAD | Bug | public | 2020-04-24 21:23 | 2021-02-07 22:08 |
Reporter | cadandre | Assigned To | |||
Priority | normal | Severity | minor | Reproducibility | always |
Status | feedback | Resolution | open | ||
Platform | PC | OS | Windows | OS Version | 10 |
Product Version | 0.18 | ||||
Target Version | 0.20 | ||||
Summary | 0004323: Import of any .dae (Collada)-file fails | ||||
Description | According to https://wiki.freecadweb.org/index.php?title=Extra_python_modules#pyCollada FreeCAD on Windows should be able to open/import .dae-files Quote: 'Windows On Windows since 0.15 pycollada is included in both the FreeCAD release and developer builds so no additional steps are necessary.' Nevertheless every import of .dae-files (Open as well as Import) fails (see screenshot attached). If somebody tells me where to find the errormessage at the bottom of the screenshot, I could provide it. | ||||
Steps To Reproduce | open/import any .dae-file | ||||
Tags | #post-to-forum, 0.18 | ||||
FreeCAD Information | OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.4 (GitTag) Build type: Release Branch: releases/FreeCAD-0-18 Hash: 980bf9060e28555fecd9e3462f68ca74007b70f8 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
@cadandre : please address your issue according our reporting guidelines by opening a topic in our forum. Thx |
Here's an example DAE file for testing. ExampleCollada.dae (15,833 bytes)
<?xml version="1.0" encoding="UTF-8"?> <COLLADA xmlns="http://www.collada.org/2005/11/COLLADASchema" version="1.4.1"> <asset> <contributor> <authoring_tool>Converted by the PolyTrans Collada exporter</authoring_tool> </contributor> <created>20XX-04-09T14:24:50Z</created> <modified>20XX-04-09T14:24:50Z</modified> <unit meter="0.010000" name="centimeters"/> <up_axis>Y_UP</up_axis> </asset> <library_images> <image id= "ceramic_tif" name= "ceramic_tif" > <init_from>file: ///ceramic.tif </init_from> </image> </library_images> <library_materials> <material id="default" name="default_1"> <instance_effect url="#default-fx"/> </material> <material id="floor__ceramic__tiled" name="floor__ceramic__tiled_1"> <instance_effect url="#floor__ceramic__tiled-fx"/> </material> </library_materials> <library_effects> <effect id="default-fx" name="default_2"> <profile_COMMON> <technique sid="common"> <phong> <emission> <color>0.000000 0.000000 0.000000 1</color> </emission> <ambient> <color>0.300000 0.300000 0.300000 1</color> </ambient> <diffuse> <color>0.400000 0.400000 0.400000 1</color> </diffuse> <specular> <color>0.700000 0.700000 0.700000 1</color> </specular> <shininess> <float>16.000000</float> </shininess> <reflective> <color>0.000000 0.000000 0.000000 1</color> </reflective> <reflectivity> <float>0.000000</float> </reflectivity> <transparent opaque="A_ONE"> <color>1.000000 1.000000 1.000000 1</color> </transparent> <transparency> <float>1.000000</float> </transparency> <index_of_refraction> <float>1.000000</float> </index_of_refraction> </phong> <extra> <technique profile="OKINO"> <filter_color> <color>1.000000 1.000000 1.000000 1</color> </filter_color> <phong> <shininess>32</shininess> <metal>0.000000</metal> </phong> <shading_coefficients> <ambient>0.300000</ambient> <diffuse>0.400000</diffuse> <specular>0.700000</specular> <luminous>0.000000</luminous> <reflect>0.000000</reflect> <filter>1.000000</filter> </shading_coefficients> <opacity> <face>1.000000</face> <reflect>1.000000</reflect> <edge>1.000000</edge> <edge_exponent> 1.000000 </edge_exponent> <edge_enable>0</edge_enable> </opacity> </technique> </extra> </technique> </profile_COMMON> </effect> <effect id="floor__ceramic__tiled-fx" name="floor__ceramic__tiled_2"> <profile_COMMON> <newparam sid= "ceramic_tif-surface" > <surface type="2D"> <init_from>ceramic_tif</init_from> </surface> </newparam> <newparam sid="ceramic_tif-sampler"> <sampler2D> <source>ceramic_tif-surface</source> <wrap_s>WRAP</wrap_s> <wrap_t>WRAP</wrap_t> <minfilter>LINEAR_MIPMAP_LINEAR</minfilter> <magfilter>LINEAR</magfilter> </sampler2D> </newparam> <technique sid="common"> <phong> <emission> <color>0.000000 0.000000 0.000000 1</color> </emission> <ambient> <color>0.300000 0.300000 0.300000 1</color> </ambient> <diffuse> <texture texture="ceramic_tif-sampler" texcoord="uv0"> <extra> <technique profile="OKINO"> <weighting>1.000000</weighting> <modulation_source>rgb</modulation_source> <color_blending_mask>off</color_blending_mask> <mix_with_previous_layer>1.000000</mix_with_previous_layer> </technique> <technique profile="MAX3D"> <amount>1.000000</amount> </technique> <technique profile="MAYA"> <wrapU>1</wrapU> <wrapV>1</wrapV> <repeatU>1.000000</repeatU> <repeatV>1.000000</repeatV> <offsetU>0.000000</offsetU> <offsetV>0.000000</offsetV> <rotateUV>0.000000</rotateUV> </technique> </extra> </texture> </diffuse> <specular> <color>0.250000 0.250000 0.250000 1</color> </specular> <shininess> <float>16.000000</float> </shininess> <reflective> <color>0.000000 0.000000 0.000000 1</color> </reflective> <reflectivity> <float>0.000000</float> </reflectivity> <transparent opaque="A_ONE"> <color>1.000000 1.000000 1.000000 1</color> </transparent> <transparency> <float>1.000000</float> </transparency> <index_of_refraction> <float>1.000000</float> </index_of_refraction> </phong> <extra> <technique profile="OKINO"> <filter_color> <color>1.000000 1.000000 1.000000 1</color> </filter_color> <phong> <shininess>32</shininess> <metal>0.000000</metal> </phong> <shading_coefficients> <ambient>0.300000</ambient> <diffuse>0.568627</diffuse> <specular>0.250000</specular> <luminous>0.000000</luminous> <reflect>0.000000</reflect> <filter>1.000000</filter> </shading_coefficients> <opacity> <face>1.000000</face> <reflect>1.000000</reflect> <edge>1.000000</edge> <edge_exponent>1.000000</edge_exponent> <edge_enable>0</edge_enable> </opacity> </technique> <technique profile="FCOLLADA"> <bump> <texture texture="ceramic_tif-sampler" texcoord="uv0"> <extra> <technique profile="OKINO"> <weighting>0.050000</weighting> <modulation_source>rgb</modulation_source> </technique> <technique profile="MAX3D"> <amount>0.050000</amount> </technique> <technique profile="MAYA"> <wrapU>1</wrapU> <wrapV>1</wrapV> <repeatU>1.000000</repeatU> <repeatV>1.000000</repeatV> <offsetU>0.000000</offsetU> <offsetV>0.000000</offsetV> <rotateUV>0.000000</rotateUV> </technique> </extra> </texture> </bump> </technique> </extra> </technique> </profile_COMMON> </effect> </library_effects> <library_cameras> <camera id="default-camera" name="default_3"> <optics> <technique_common> <perspective> <xfov>28.072487</xfov> <yfov>28.072487</yfov> <znear>0.010000</znear> <zfar>1000000.000000</zfar> </perspective> </technique_common> </optics> <extra> <technique profile="OKINO"> <interestdist>32.015621</interestdist> </technique> <technique profile="XSI"> <XSI_Camera> <xsi_param sid="interestdist">32.015621</xsi_param> </XSI_Camera> </technique> </extra> </camera> </library_cameras> <library_lights> <light id="defaultambient-light" name="defaultambient"> <technique_common> <ambient> <color>1.000000 1.000000 1.000000</color> </ambient> </technique_common> </light> <light id="light-light" name="light"> <technique_common> <directional> <color>1.000000 1.000000 1.000000</color> </directional> </technique_common> </light> <light id="light-light_1" name="light_1"> <technique_common> <directional> <color>1.000000 1.000000 1.000000</color> </directional> </technique_common> </light> </library_lights> <library_geometries> <geometry id="rectangle_object-mesh" name="rectangle_object"> <mesh> <source id="rectangle_object-mesh-positions"> <float_array id="rectangle_object-mesh-positions-array" count="12"> -2.000000 -2.000000 0.000000 -2.000000 2.000000 0.000000 2.000000 -2.000000 0.000000 2.000000 2.000000 0.000000</float_array> <technique_common> <accessor source="#rectangle_object-mesh-positions-array" count="4" stride="3"> <param name="X" type="float"/> <param name="Y" type="float"/> <param name="Z" type="float"/> </accessor> </technique_common> </source> <source id="rectangle_object-mesh-normals"> <float_array id="rectangle_object-mesh-normals-array" count="3"> 0.000000 0.000000 1.000000</float_array> <technique_common> <accessor source="#rectangle_object-mesh-normals-array" count="1" stride="3"> <param name="X" type="float"/> <param name="Y" type="float"/> <param name="Z" type="float"/> </accessor> </technique_common> </source> <source id="rectangle_object-mesh-map-channel1"> <float_array id="rectangle_object-mesh-map-channel1-array" count="8"> 0.000000 0.000000 0.000000 1.000000 1.000000 0.000000 1.000000 1.000000</float_array> <technique_common> <accessor source="#rectangle_object-mesh-map-channel1-array" count="4" stride="2"> <param name="S" type="float"/> <param name="T" type="float"/> </accessor> </technique_common> </source> <source id="rectangle_object-mesh-tangent1"> <float_array id="rectangle_object-mesh-tangent1-array" count="3"> 1.000000 0.000000 0.000000</float_array> <technique_common> <accessor source="#rectangle_object-mesh-tangent1-array" count="1" stride="3"> <param name="X" type="float"/> <param name="Y" type="float"/> <param name="Z" type="float"/> </accessor> </technique_common> </source> <source id="rectangle_object-mesh-binormal1"> <float_array id="rectangle_object-mesh-binormal1-array" count="3"> 0.000000 1.000000 0.000000</float_array> <technique_common> <accessor source="#rectangle_object-mesh-binormal1-array" count="1" stride="3"> <param name="X" type="float"/> <param name="Y" type="float"/> <param name="Z" type="float"/> </accessor> </technique_common> </source> <vertices id="rectangle_object-mesh-vertices"> <input semantic="POSITION" source="#rectangle_object-mesh-positions"/> </vertices> <polylist material="NUGRAF___SPECIAL_INHERITED_SURFACE_MARKER" count="1"> <input semantic="VERTEX" source="#rectangle_object-mesh-vertices" offset="0"/> <input semantic="NORMAL" source="#rectangle_object-mesh-normals" offset="1"/> <input semantic="TEXCOORD" source="#rectangle_object-mesh-map-channel1" offset="2" set="1"/> <input semantic="TANGENT" source="#rectangle_object-mesh-tangent1" offset="3" set="1"/> <input semantic="BINORMAL" source="#rectangle_object-mesh-binormal1" offset="4" set="1"/> <vcount>4 </vcount> <p>0 0 0 0 0 2 0 2 0 0 3 0 3 0 0 1 0 1 0 0 </p> </polylist> </mesh> </geometry> </library_geometries> <library_visual_scenes> <visual_scene id="RootNode" name="RootNode"> <node id="default-node" name="default_3" type="NODE"> <translate>20.000000 15.000000 20.000000</translate> <rotate>-0.503521 0.838431 0.208565 52.581881</rotate> <scale>1.000000 1.000000 1.000000</scale> <instance_camera url="#default-camera"/> </node> <node id="defaultambient-node" name="defaultambient" type="NODE"> <instance_light url="#defaultambient-light"/> </node> <node id="light-node" name="light" type="NODE"> <translate>-99.999992 99.999992 49.999996</translate> <rotate>-0.809017 -0.500000 0.309017 74.754734</rotate> <scale>1.000000 1.000000 1.000000</scale> <instance_light url="#light-light"/> </node> <node id="light-node_1" name="light_1" type="NODE"> <translate>99.999992 99.999992 49.999996</translate> <rotate>-0.809017 0.500000 -0.309017 74.754734</rotate> <scale>1.000000 1.000000 1.000000</scale> <instance_light url="#light-light_1"/> </node> <node id="rectangle-node" name="rectangle" type="NODE"> <translate>0.000000 2.000000 0.000000</translate> <instance_geometry url="#rectangle_object-mesh"> <bind_material> <technique_common> <instance_material symbol="NUGRAF___SPECIAL_INHERITED_SURFACE_MARKER" target="#floor__ceramic__tiled"> <bind_vertex_input semantic="uv0" input_semantic="TEXCOORD" input_set="1"/> </instance_material> </technique_common> </bind_material> </instance_geometry> </node> <extra> <technique profile="OKINO"> <scene_bounding_min>-2.000000 0.000000 0.000000</scene_bounding_min> <scene_bounding_max>2.000000 4.000000 0.000000</scene_bounding_max> </technique> <technique profile="MAX3D"> <frame_rate>30</frame_rate> </technique> <technique profile="XSI"> <SI_Scene> <xsi_param sid="frameRate">30</xsi_param> <xsi_param sid="start">0.000000</xsi_param> <xsi_param sid="end">3.333333</xsi_param> <xsi_param sid="timing">"SECONDS"</xsi_param> </SI_Scene> <SI_Ambience> <xsi_param sid="red">1.000000</xsi_param> <xsi_param sid="green">1.000000</xsi_param> <xsi_param sid="blue">1.000000</xsi_param> </SI_Ambience> </technique> <technique profile="FCOLLADA"> <start_time>0.000000</start_time> <end_time>3.333333</end_time> </technique> </extra> </visual_scene> </library_visual_scenes> <scene> <instance_visual_scene url="#RootNode"/> </scene> </COLLADA> |
I am able to load the example file under the following: OS: Windows 10 Version 2004 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.23971 (Git) Build type: Release Branch: master Hash: a3fb41502b079a86175e6a414d82956a48bab4e2 Python version: 3.8.6+ Qt version: 5.15.1 Coin version: 4.0.1 OCC version: 7.5.0 Locale: English/United States (en_US) |
This ticket has been migrated to GitHub as issue 6050. |
2020-04-24 21:23 | cadandre | New Issue | |
2020-04-24 21:23 | cadandre | Tag Attached: 0.18 | |
2020-04-24 21:23 | cadandre | File Added: dae_import_fails.png | |
2020-04-24 22:38 | openBrain | Tag Attached: #post-to-forum | |
2020-04-24 22:38 | openBrain | Status | new => feedback |
2020-04-24 22:38 | openBrain | Note Added: 0014371 | |
2021-02-06 06:49 | abdullah | Target Version | => 0.20 |
2021-02-07 21:41 | chennes | Note Added: 0015303 | |
2021-02-07 21:41 | chennes | File Added: ExampleCollada.dae | |
2021-02-07 22:08 | chennes | Note Added: 0015304 |
