| 0004336 | FreeCAD | Bug | public | 2020-05-07 13:14 | 2020-05-11 12:12 |
| Reporter | Andre-3D | Assigned To | |||
| Priority | normal | Severity | minor | Reproducibility | random |
| Status | closed | Resolution | suspended | ||
| Summary | 0004336: Object going back to old position in placement tool when i undo/re-do the action with ctrl-z and do some mesurementchanges | ||||
| Description | Object jump back to old position in placement tool when i undo/re-do the action with ctrl-z and ctrl-y and do some mesurementchanges with the z-position, y-position and x-position and when i do inbetween measurements moretimes with the linial and do changes with z ,y and x adjustment and when i hit the ok button the object jump back before the changes/adjustment. i hope i described it clear enough. the bug/fault happens not all the time . i have this so long i use freecad (sinds 0.17) under windows 10 and (k)ubuntu. pitty enough because freecad is a good program. (relative) easy to understand a powerful enough for average user. i hope i described it clear enough that you can reproduce the fault/bug beause freecad is good program. | ||||
| Steps To Reproduce | klhhklhk | ||||
| Additional Information | kklkk | ||||
| FreeCAD Information | hkhkk | ||||
@Andre-3D : please address your issue following our reporting guidelines by opening first a new topic in our forum. Please get familiar with the help how-to before. Thanks. According volume of missing information in this ticket, I close and it will be reopen if needed. |
