| 0000437 | Sketcher | Feature | public | 2011-09-13 10:40 | 2014-01-26 22:39 |
| Reporter | galou_breizh | Assigned To | |||
| Summary | 0000437: Sketcher: ask for value immediatly after creating a length constraint | ||||
| Description | I think it would be practical to ask for a value immediately after creation of a constraint where a value is required. For the moment, the constraint is created with the current value and the user has to double-click on the value to change it. Usually, the value is incorrect when the constraint is created and the user does want to modify it. | ||||
I think the most common practice for creating a sketch is: 1. create all geometry entities 2. add necessary constraints to fully constrain the sketch 3. specify the correct dimensions (often iteratively) in case the user wants to determine a dimension just after the creation of such a constraint he can easily double click on the dimension and do it. I don't think we have to bother the user with too many pop up dialogs, forcing him to follow a workflow possibly different from the one he prefers. |
I just checked on CATIA, she actually behaves like FreeCAD. I just thought that if the user doesn't want to change the value, he/she can press the ENTER key. To avoid bothering the user we could also validate the current value if the user continues his/her work by clicking somewhere else. |
Mhh, I'm not sure on this one. He is right mostly one create the dimension and immediately change the value (at least I do often in CATIA). I switch this to feedback and would like to here addition opinions... |
A typical example usage is this excellent tutorial: http://www.youtube.com/watch?v=51CwhhXeG_c The dimensions are changed right after having created the constraint. Maybe a checkable option could be created "ask for value upon constraint creation" or something in good English. |
Hi, maybe user can hold CTRL key while clicking on toolbar constraint icon. If he holds this key - dialog for dimesion appears (or vince-versa). |
another possibility would be - if the user starts pressing the number keys on the keyboard just after placing a dimension constraint - he is trying to modify the last dimension and not to rotate the view (current behavior) |
I think tilas' suggestion is very good, and a checkbox (like galou suggested) would also be good--allowing the user the option. In SolidWorks, numerical constraints are like this: " I just thought that if the user doesn't want to change the value, he/she can press the ENTER key. To avoid bothering the user we could also validate the current value if the user continues his/her work by clicking somewhere else." |
It looks to me that in many -most? - tutorials values are directly input after constraint creation: http://ubuntuone.com/3V0WEpY8JIejWP3EwzqtO2 |
but in this tutorial he reproduces a sketch from an existing blueprint. He already knows the dimensions. In general there will be two groups of users: A. those who will want to enter the dimension just after the constraint B. those that they want to enter dimension values later by iteratively trying values and checking how the sketch looks like. If we don't ask for a dimension immediately after the constraint, the group A can just double click and enter the dimension. If we ask for a dimension value then we make group A a little happier but group B much less happy because they will have to think about specific values instead of the general picture of the sketch. |
Hey that's my video :D In my current and past work, more than 90% of my modeling has been in the A scenario. I know what dimensions I want. I can't say about any other people, but I can't see the B scenario as being a specific group of exclusive users. I'm sure all users will find themselves in either "group" at one time or the other, and I have a feeling A would be more frequent (no proof of course). Can't we just have both at the same time? Case in point: in Solid Edge, the dimension field is shown in the equivalent of FreeCAD's taskview instead of in a popup dialog. Right after adding a dim constraint, it is shown in the taskview, so you can enter a value; but you don't have to. Could we somehow have the dimension shown interactively right after you add the constraint, but if you select a new element it disappears? |
the implementation of Autodesk Inventor allows the user to click on the dimension value after creating the dimension (or for that matter on any dimension when the operator is working in dimension mode) a dialog box prompting for dimension value is presented. This is a highly convenient, yet unobtrusive, way to supply dimension values. FWIW, also dimensions can be given a name in this same dialog box, like Height= 22.5 Height will appear in a parameter table with the provided value. Dimensions can also be set to the value of a pre-existing dimension by clicking on that existing dimension text while this dialog is opened. A third utility provided by this dialog is the ability to simply enter a parameter name to provide the value for the newly created dimension. |
Hi, Maybe also AutoConstraints for length can be added, and work similar to what norm says solidEdge has. in Norm's suggestion there would be some menu that appears when you click on a length constraint, and you can input value here, or not (IMO best approach would be to use Draft command bar). When you are placing polyline (or line), and have auto constraints on, you can have auto added horizontal or vertical constraints. How about making Draft Command bar active while placing line (or adding length constraints - or rotation or some other constraint), and in it you can input (but you do not have to) length, radius, angle.... Regards, Petar |
I implemented scenario A) see https://github.com/jrheinlaender/FreeCAD/commit/4361cf8f26338e17350b95f215884fd31c391f9a IMO users of scenario B) can just hit <Enter> when the dialog box pops up. I have the impression that these are the minority :-) Should I make the automatic dialog box pop-up dependent on an option in the Preferences? |
Reminder sent to: logari81 I implemented scenario A) see https://github.com/jrheinlaender/FreeCAD/commit/4361cf8f26338e17350b95f215884fd31c391f9a [^] IMO users of scenario B) can just hit <Enter> when the dialog box pops up. I have the impression that these are the minority :-) Should I make the automatic dialog box pop-up dependent on an option in the Preferences? |
I have to say I'm also in the camp of drawing first and constraining later. Reproducing a Blue print is a nice Tutorial, but its not a design flow. If you auto length, your sketch get very rigid from the start, and you can not move points and lines any more. Then the whole point of such a sketcher is muted.... But I can go with a preference entry which you can switch on that behavior. But the default should be OFF! |
Jriegel, From what I understand, jrheinlander is not talking about inputing auto length constraints as you draw, only to pop up a dialog when you create a dimensional constraint. If you don't put constraints, your sketch remains flexible. The idea is that when you want to apply constraints, it's to make your sketch rigid, and you know what dimension you want, so opening the dimension field dialog automatically saves the need to double-click on the dimension you just created. And BTW this is how I work, even when I'm designing from scratch, and not following a blueprint. ;-) |
How can we come to a consensus on this? Its a trivial addition to the code. |
I would say the following: Standard behavior is insert the actual length of the object (as it is) and a option in the preferences (or Sketcher dialog) to ask immediately for a (new) value. |
I will merge jrheinlaender's patch soon |
ok, the fix is now in master. I think it is a bit of overkill to add a special preferences setting for this. Users that may want to add distance constraints and keep the default value, they can just press enter when the dialog pops up. |
| 2011-09-13 10:40 | galou_breizh | New Issue | |
| 2011-09-14 05:11 | logari81 | Note Added: 0001065 | |
| 2011-09-15 05:10 | galou_breizh | Note Added: 0001068 | |
| 2011-09-16 04:01 |
Note Added: 0001074 | |
| 2011-09-16 04:01 |
Status | new => feedback |
| 2011-09-30 06:41 | galou_breizh | Note Added: 0001137 | |
| 2011-09-30 12:58 | pperisin | Note Added: 0001138 | |
| 2011-11-01 11:44 | tilas | Note Added: 0001205 | |
| 2011-11-20 13:31 | momentumv5 | Note Added: 0001329 | |
| 2012-01-21 22:59 | galou_breizh | Note Added: 0001596 | |
| 2012-01-22 08:42 | logari81 | Note Added: 0001597 | |
| 2012-01-30 02:25 | normandc | Note Added: 0001606 | |
| 2012-04-01 18:54 | djreichel | Note Added: 0001842 | |
| 2012-04-02 07:05 | pperisin | Note Added: 0001849 | |
| 2012-05-05 17:50 | yorik | Project | FreeCAD => Sketcher |
| 2013-01-18 13:50 | jrheinlaender | Note Added: 0002856 | |
| 2013-01-18 13:57 | jrheinlaender | Note Added: 0002857 | |
| 2013-01-21 17:45 |
Note Added: 0002868 | |
| 2013-01-21 23:46 | normandc | Note Added: 0002869 | |
| 2013-02-21 05:11 | jrheinlaender | Note Added: 0002931 | |
| 2013-02-21 16:15 |
Note Added: 0002935 | |
| 2013-02-21 17:29 | logari81 | Note Added: 0002936 | |
| 2013-02-22 09:34 | logari81 | Note Added: 0002938 | |
| 2013-02-22 09:34 | logari81 | Status | feedback => closed |
| 2013-02-22 09:34 | logari81 | Resolution | open => fixed |
| 2013-02-22 09:34 | logari81 | Fixed in Version | => trunk |
| 2014-01-26 22:39 | yorik | Product Version | trunk => 0.14 |
| 2014-01-26 22:39 | yorik | Fixed in Version | trunk => 0.14 |
