| 0004406 | Path | Bug | public | 2020-07-15 06:56 | 2021-02-06 06:33 |
| Reporter | janc.linders | Assigned To | |||
| Summary | 0004406: Increasing Memory usage when using Path WB and Adaptive Processing | ||||
| Description | Using the PATH WB and Adaptive processing not releasing memory. Repeating the PostProcessing into a GRBL file increases the memory use until exhausted. | ||||
| Steps To Reproduce | A simple test file is over 2 Mb. Not able to attach. Is there another way to share this ? Here are the steps. Goto PART WB Create 2 simple boxes (10,10,10) (5,5,5) Cut small from big box leaving a pocket in the huge box Switch the PATH WB. Process the pocket using Adaptive Processing. Post Process to GRBL Lowering the StepDown from 0,1 mm to 0,01 mm shows it even better. | ||||
| Tags | #post-to-forum | ||||
| FreeCAD Information | OS: Ubuntu 18.04.4 LTS (LXDE/Lubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.21975 (Git) Build type: Unknown Branch: master Hash: 9b18c2dc196e294ed00850897894eb5d0d9435a2 Python version: 3.6.9 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
|  | @janc.linders : please address your issue by first opening a topic in our forum (as per our reporting guidelines). Thx |
|  | @openBrain : Hi , Sure, I'll address this is the forum first. Should i place the status of this in suspended ? Regards, |
|  | @janc.linders : don't care too much about the status. :) Please just cross-post links between here and the topic you'll open. ;) Thx |
|  | @janc.linders has this been posted to the forum yet? |
|  | @Kunda1 , yes it has been posted in the forum. See : Using the PATH WB and Adaptive processing not releasing memory. Repeating the PostProcessing into a GRBL file increases. |
|  | I believe the issue is related to this discussion. https://forum.freecadweb.org/viewtopic.php?f=15&t=50583 A PR is pending. |
|  | Can this issue be retested since FreeCAD master ab4ab444 was committed ? Please update to the latest v0.19 to test. @sliptonic @janc.linders |
|  | I have downloaded the latest nightly. Is that ok to test the resolution for this issue ? OS: Ubuntu 18.04.5 LTS (XFCE/xubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Branch: unknown Hash: 71cd301ca78259c55398a0919e3277fe3cc0a390 Python version: 3.6.9 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) |
|  | In my testing, the situation is better but not completely resolved.  I think there's still a memory leak related only to the adaptive operation and having nothing to do with the grbl post. There's still one change to the grbl post which has not been merged yet. |
|  | First testing shows indeed an improvement. Less increase. :-) Also (for me at least) a strange behavior is that after you completely close the design , the memory stays high. I would expect that memory use drops after closing a document. Restarting and loading the model brings it back to the start usage. |
|  | This ticket has been migrated to GitHub as issue 6092. |
| 2020-07-15 06:56 | janc.linders | New Issue | |
| 2020-07-25 09:47 | openBrain | Note Added: 0014684 | |
| 2020-07-25 09:47 | openBrain | Status | new => feedback |
| 2020-07-25 09:47 | openBrain | Tag Attached: #post-to-forum | |
| 2020-07-25 14:33 | janc.linders | Note Added: 0014688 | |
| 2020-07-25 14:33 | janc.linders | Status | feedback => new |
| 2020-07-25 16:54 | openBrain | Note Added: 0014689 | |
| 2020-07-31 13:10 | Kunda1 | Note Added: 0014693 | |
| 2020-07-31 19:19 | janc.linders | Note Added: 0014695 | |
| 2020-10-06 23:07 | sliptonic | Note Added: 0014783 | |
| 2020-10-15 15:58 | Kunda1 | Note Added: 0014866 | |
| 2020-10-15 17:30 | janc.linders | Note Added: 0014870 | |
| 2020-10-15 17:49 | sliptonic | Note Added: 0014871 | |
| 2020-10-15 17:54 | janc.linders | Note Added: 0014872 | |
| 2021-02-06 06:33 | abdullah | Target Version | => 0.20 |
