| 0004411 | Path | Bug | public | 2020-07-30 07:53 | 2020-10-15 03:41 |
| Reporter | racemaniac | Assigned To | sliptonic | ||
| Summary | 0004411: Can't regenerate pocket toolpath in certain cases | ||||
| Description | Forum thread discussing the issue For attached example file: after creating a pocket operation, any refresh to the pocket toolpath fails. Workaround: manually triggering a recompute of the object. | ||||
| Steps To Reproduce | Open the file Start a job (default settings) Create a pocket operation for the highlighted plane, all default settings Make any change, for example set step over to 80 -> it fails. From then on you can do whatever you want, it'll no longer create any toolpath for that plane with the pocket operation... | ||||
| Additional Information | Can be worked around by doing a recompute on the body, and then refreshing the toolpath | ||||
| FreeCAD Information | FreeCAD version: OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22111 (Git) Build type: Release Branch: master Hash: cb2099aa6bb287a8d7843eb70684cce79bdef26b Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Dutch/Belgium (nl_BE) | ||||
Mantis cleanup. This appears to be fixed by an earlier PR. I can't reproduce the problem at this time. |
| 2020-07-30 07:53 | racemaniac | New Issue | |
| 2020-07-30 07:53 | racemaniac | File Added: Bug.FCStd | |
| 2020-10-15 03:41 | sliptonic | Assigned To | => sliptonic |
| 2020-10-15 03:41 | sliptonic | Status | new => closed |
| 2020-10-15 03:41 | sliptonic | Resolution | open => fixed |
| 2020-10-15 03:41 | sliptonic | Note Added: 0014856 |
