| 0004412 | PartDesign | Bug | public | 2020-08-01 15:49 | 2021-02-06 06:43 |
| Reporter | MRx | Assigned To | |||
| Priority | urgent | Severity | major | Reproducibility | always |
| Summary | 0004412: Pockets into a circular hole and refining object damages the object structure | ||||
| Description | I've created a sample project, and it seems creating a vertical circular pocket into a horizontal circular pocket damages the object structure. 1. create some shape with horizontal pockets 2. create some vertical pockets touching the horizontal pockets 3. run refine object 4. run check geometry it gives a lot invalid curve on surface. A sample project is attached. It happened to me on 2 other objects, all I could do is to redraw the object when this happened. OS: macOS Mojave (10.14) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.21938 (Git) Build type: Release Branch: master Hash: 5666598a6be219830a992610243fe23144a61453 Python version: 3.8.2 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) Forum Post: https://forum.freecadweb.org/viewtopic.php?f=3&t=49154&p=421135#p421094 | ||||
With FreeCad 0.19 I have to refine an object and create a simple copy. With FreeCad 0.18 it's enough to refine the object and the history can be deleted. Is this intended? |
This ticket has been migrated to GitHub as issue 6095. |
| 2020-08-01 15:49 | MRx | New Issue | |
| 2020-08-01 15:49 | MRx | File Added: fc_shapebug.FCStd | |
| 2020-08-02 00:30 | MRx | Note Added: 0014696 | |
| 2020-08-02 02:51 | MRx | Description Updated | |
| 2020-08-02 02:51 | MRx | FreeCAD Information | <!--ATTENTION: COMPLETELY ERASE THIS AFTER PASTING YOUR Help > About FreeCAD > Copy to clipboard NOTE: just the snippet alone will do without anything else included. The ticket will not be submitted without it. --> => <!--ATTENTION: COMPLETELY ERASE THIS AFTER PASTING YOUR Help > About FreeCAD > Copy to clipboard NOTE: just the snippet alone will do without anything else included. The ticket will not be submitted without it. --> |
| 2020-08-02 05:39 | MRx | Description Updated | |
