0004415FreeCADBugpublic2021-02-06 06:49
ReporterRoy_043 Assigned To
Status newResolutionopen
Target Version0.20
Summary0004415: Toolbar-only command must be visible for custom shortcut to work
DescriptionFor some reason a toolbar-only command (= a command that is not included in any menu) must be visible for the assigned custom shortcut to work. This seems like a strange limitation. One of the reasons for assigning shortcuts can be that you do not want to display the toolbar.
Steps To Reproduce
  1. Invoke the Std_DlgCustomize command.
  2. Assign a shortcut to the Std_Part command. The command can be found in the Structure category.
  3. Test the shortcut with the Structure toolbar visible.
  4. Result: OK.
  5. Disable the Structure toolbar.
  6. Re-test the shortcut.
  7. Result: the shortcut does not work anymore.
Additional InformationBug topic:
https://forum.freecad.org/viewtopic.php?f=3&t=45896
openBrain's analysis:
https://forum.freecad.org/viewtopic.php?f=3&t=48949#p419162
FreeCAD InformationOS: Windows 8.1 (6.3)
Version: 0.19.22111 (Git)
Hash: cb2099aa6bb287a8d7843eb70684cce79bdef26b
Python version: 3.6.8
Qt version: 5.12.1
Locale: Dutch/Netherlands (nl_NL)
yorik
2022-03-03 13:55
administrator   ~0016930
This ticket has been migrated to GitHub as issue 6097.
2020-08-03 12:40 Roy_043 New Issue
