| 0004433 | Path | Bug | public | 2020-09-10 22:08 | 2020-09-15 19:30 |
| Reporter | mandd | Assigned To | russ4262 | ||
| OS | Debian | OS Version | 11 | ||
| Summary | 0004433: profile operation cut side resets | ||||
| Description | https://forum.freecadweb.org/viewtopic.php?f=15&t=49459 | ||||
| Steps To Reproduce | when re-selecting/changing geometry on existing profile operation, cut side is reset to "outside" even if it was set to "inside" prior. | ||||
| FreeCAD Information | OS: Debian GNU/Linux bullseye/sid (XFCE/lightdm-xsession) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22279 (Git) Build type: Unknown Branch: feature/base_geometry_fix Hash: b9f308b0112eea742b9c7f9a05a664afed4b6bf5 Python version: 3.8.5 Qt version: 5.14.2 Coin version: 4.0.0 OCC version: 7.4.0 Locale: English/Canada (en_CA) | ||||
FreeCAD: master 47b27edd 2020-09-12 05:24:25 Details Diff |
[Path] Fixes 0004433 - `Cut Side` reset with certain Base Geometry changes `Cut Side` value was hard-coded to reset when Base Geometry was empty. This disallowed retention of the current value with changes to selected Base Geometry involving the clearing thereof. Also restored fixed visibility to `Cut Side` option in Task panel editor per forum mention. |
Affected Issues 0004433 |
| mod - src/Mod/Path/PathScripts/PathProfileGui.py | Diff File | ||
FreeCAD: master 2921a0c6 2020-09-15 19:12:01 Committer: GitHub Details Diff |
Merge pull request 0003861 from Russ4262/profile_reset_fix [Path] Fixes 0004433 - `Cut Side` reset with certain Base Geometry changes |
| 2020-09-10 22:08 | mandd | New Issue | |
| 2020-09-15 19:30 | sliptonic | Changeset attached | => FreeCAD master 2921a0c6 |
| 2020-09-15 19:30 | russ4262 | Changeset attached | => FreeCAD master 47b27edd |
| 2020-09-15 19:30 | russ4262 | Note Added: 0014756 | |
| 2020-09-15 19:30 | russ4262 | Assigned To | => russ4262 |
| 2020-09-15 19:30 | russ4262 | Status | new => closed |
| 2020-09-15 19:30 | russ4262 | Resolution | open => fixed |
