| 0000444 | FreeCAD | Bug | public | 2011-10-04 21:06 | 2011-10-05 06:41 |
| Reporter | normandc | Assigned To | |||
| Summary | 0000444: makePipe: unwanted twisting of section along helix used as wire | ||||
| Description | As told in the forum topic https://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=3&t=1461 Using an helix as wire for the makePipe command, the section twists along the wire. This is not the expected behavior. Steps to reproduce: in the Python console: import Part, FreeCAD, math from FreeCAD import Base helix = Part.makeHelix(1,10,3) edge1 = Part.makeLine((2.5,0,-0.125), (2.5,0,0.125)) edge2 = Part.makeLine((2.5,0,0.125), (3.1,0,0.419)) edge3 = Part.makeLine((3.1,0,0.419), (3.1,0,-0.419)) edge4 = Part.makeLine((3.1,0,-0.419), (2.5,0,-0.125)) section = Part.Wire([edge1,edge2,edge3,edge4]) pipe = Part.Wire(helix).makePipe(section) Part.show(pipe) First attachment shows the result in FreeCAD. Second shows the result in a pro CAD program (Solid Edge). | ||||
| Additional Information | OS: Ubuntu 11.10 Oneiric Ocelot Beta 2 64-Bit FreeCAD version 0.12-bzr4629 from PPA | ||||
2011-10-04 21:06
2011-10-04 21:07
Fixed in r4991 The code must be changed to: import Part, FreeCAD, math from FreeCAD import Base helix = Part.makeHelix(1,10,3) edge1 = Part.makeLine((2.5,0,-0.125), (2.5,0,0.125)) edge2 = Part.makeLine((2.5,0,0.125), (3.1,0,0.419)) edge3 = Part.makeLine((3.1,0,0.419), (3.1,0,-0.419)) edge4 = Part.makeLine((3.1,0,-0.419), (2.5,0,-0.125)) section = Part.Wire([edge1,edge2,edge3,edge4]) makeSolid=0 isFrenet=1 pipe = Part.Wire(helix).makePipeShell([section],makeSolid,isFrenet) Part.show(pipe) |
| 2011-10-04 21:06 | normandc | New Issue | |
| 2011-10-04 21:06 | normandc | File Added: fc_thread_twistingsection.png | |
| 2011-10-04 21:07 | normandc | File Added: se_correct_helix_protrusion.jpg | |
| 2011-10-05 06:41 | wmayer | Note Added: 0001140 | |
| 2011-10-05 06:41 | wmayer | Status | new => closed |
| 2011-10-05 06:41 | wmayer | Resolution | open => fixed |
| 2011-10-05 06:41 | wmayer | Fixed in Version | => 0.12 |
