| 0004445 | FreeCAD | Bug | public | 2020-09-26 23:46 | 2021-03-13 21:29 |
| Reporter | mrjohnc | Assigned To | Kunda1 | ||
| Priority | none | Severity | crash | Reproducibility | always |
| Status | resolved | Resolution | fixed | ||
| Target Version | 0.20 | Fixed in Version | 0.19 | ||
| Summary | 0004445: FreeCAD menus and buttons very slow (Linux version) on ChromeOS (GPU Acceleration must be enabled) | ||||
| Description | FreeCAD menus and buttons | ||||
| Steps To Reproduce | Install FreeCAD 0.18 using snap, flathub or appimage Open and try to use | ||||
| Tags | ChromeOS | ||||
| FreeCAD Information | OS: KDE Flatpak runtime Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14555 (Git shallow) Build type: Release Branch: (HEAD detached at 783e134) Hash: 783e1346c7a078f5265c3f0c6a927d09a8c1fe70 Python version: 3.7.4 Qt version: 5.14.2 Coin version: 4.0.0 OCC version: 7.3.0 Locale: English/United States (en_US) | ||||
|  | Just to add, when I try to use parts of the UI eg creating a new body parts of the UI disappear like the view controls and everything in the application box. Once I've tried to do this often FreeCAD stops responding and once closed when I try to repopen I just get a black screen and have to restart my laptop |
|  | OK, it looks like the issue is being caused by GPU acceleration, disabling GPU acceleration for Linux apps means it runs. I'm not sure how to include this as a fix |
|  | You can turn off GPU support by disabling chrome://flags/#crostini-gpu-support |
|  | @mrjohnc, Thanks for the heads up. This is good to know. A favor, next time please follow our tracker guidelines (yellow banner, top of page). It helps us with dealing with triage immensely. As you can see we are currently only accepting v0.19 bugs. Is this then something that can be replicated on v0.19? Try it quickly via AppImage CC @chrisb (we may need to add this to Known Issues thread) |
|  | Hi @Kunda1 Thanks, I can confirm that the issues remain with 0.19 when GPU acceleration enabled although they're not quite as bad its still not usable. Again disabling GPU acceleration is a workaround |
|  | @mrjohnc : could you please paste the full information about the 0.19 version your tried ? Thx |
|  | @mrjohnc ping |
|  | Updated ticket to reflect v0.19 only |
|  | @openBrain and @Kunda1 thanks, its the latest version available on Flathub as of now. I'm happily using it with GPU acceleration turned off, I'm unsure if its an issue with the OS, Linux support is still in Beta. My suggestion would just be to have some guidance on ChromeOS installation with a little not to say 'if you have issues with the interface turn off GPU acceleration in chrome://flags |
|  | @mrjohnc where do you propose we should display this note so ChromeOS users see it? BTW, the problem goes away with GPU acceleration then? *confused* |
|  | @Kunda1 I think that instructions should live here https://wiki.freecadweb.org/Install_on_Unix And then maybe a small note on this page in the Linux section on the downloads page saying something like 'including Chromebooks with Linux support' https://www.freecadweb.org/downloads.php The Chromebook instructions could be something like this, are you able to add it? ==Chromebooks with Linux support== FreeCAD can be installed on Intel based Chromebooks with Linux support (link https://www.chromium.org/chromium-os/chrome-os-systems-supporting-linux) # Enable Linux support (https://support.google.com/chromebook/answer/9145439?hl=en-GB) # Enable Flatpak installation using the terminal (https://flatpak.org/setup/Chrome%20OS/) # Install FreeCAD via Flathub using the command line instructions (https://flathub.org/apps/details/org.freecadweb.FreeCAD) # Find FreeCAD in your Linux Apps folder Note: there is an issue with some Chromebooks which causes UI problems in FreeCAD, this can be solved by disabling Linux GPU acceleration in Chrome Flags (chrome://flags/#crostini-gpu-support) ---- There are some other ways to achieve installing it but this is the one with the least steps and most simple for new users. |
|  | @kkremitzki what do you think? Should we put this on the site and/or the Github release page ? |
|  | Sure, if there are platform-specific instructions needed, it seems pretty reasonable to expand the "For distro-specific instructions..." sentence on the downloads page to specifically mention them, as Chromebooks are extensively used in education. |
|  | @sgrogan please update the 0.19 Release page mentioning Chromebook support. Here's the suggested text (please modify as you see fit)  |
|  | @Kunda1 sorry to miss this before, I think this is good, please can you add it? |
|  | pinged @sgrogan via the forum. Hope he gets it this time ;) |
|  | sgrogan has added a note to the release page. Closing this ticket. |
|  | correcting message |
|  | @Kunda1, I just spotted an error in the message you suggested, it only works if you disable GPU acceleration, not enable it, it should read (adding a few more instructions) Chromebook We understand through our forum users that FreeCAD can successfully run on Chromebooks which have Linux support https://support.google.com/chromebook/answer/9145439?hl=en-GB The only caveat known to us is the need to disable GPU acceleration via chrome://flags/#crostini-gpu-support The easiest way to install it is to enable Flatpak https://flatpak.org/setup/Chrome%20OS/ and then install using this link https://flathub.org/apps/details/org.freecadweb.FreeCAD |
|  | Sorry, @mrjohnc, lots going on ATM. Thanks for the orientation. @sgrogan please copy/paste (again) this corrected version to 0.19_pre Release page  |
|  | Ok, sorry for the delay! Too much going on. I've updated the release page to reflect the correct message. https://github.com/FreeCAD/FreeCAD/releases/tag/0.19_pre Resolving |
|  | This ticket has been migrated to GitHub as issue 6107. |
| 2020-09-26 23:46 | mrjohnc | New Issue | |
| 2020-09-27 08:14 | mrjohnc | Note Added: 0014768 | |
| 2020-09-27 09:33 | mrjohnc | Note Added: 0014769 | |
| 2020-09-27 09:34 | mrjohnc | Note Added: 0014770 | |
| 2020-09-27 11:19 | Kunda1 | Note Added: 0014771 | |
| 2020-09-27 11:19 | Kunda1 | Tag Attached: #post-to-forum | |
| 2020-09-27 11:48 | mrjohnc | Note Added: 0014772 | |
| 2020-10-09 21:27 | openBrain | Note Added: 0014810 | |
| 2020-10-22 11:26 | Kunda1 | Note Added: 0014923 | |
| 2020-10-22 11:26 | Kunda1 | Tag Attached: ChromeOS | |
| 2020-10-22 11:27 | Kunda1 | Summary | FreeCAD menus and buttons don't work on Linux version run on ChromeOS => FreeCAD menus and buttons <s>don't work</s> very slow on Linux version run on ChromeOS (GPU Acceleration must be enabled) |
| 2020-10-22 11:29 | Kunda1 | Summary | FreeCAD menus and buttons <s>don't work</s> very slow on Linux version run on ChromeOS (GPU Acceleration must be enabled) => FreeCAD menus and buttons |
| 2020-10-22 11:31 | Kunda1 | Product Version | 0.18 => 0.19 |
| 2020-10-22 11:31 | Kunda1 | Summary | FreeCAD menus and buttons |
| 2020-10-22 11:31 | Kunda1 | Description Updated | |
| 2020-10-22 11:31 | Kunda1 | Note Added: 0014925 | |
| 2020-10-22 11:45 | mrjohnc | Note Added: 0014926 | |
| 2020-10-22 15:45 | Kunda1 | Note Added: 0014927 | |
| 2020-10-22 16:50 | mrjohnc | Note Added: 0014931 | |
| 2020-10-22 16:50 | mrjohnc | Note Edited: 0014931 | |
| 2020-10-22 16:52 | mrjohnc | Note Edited: 0014931 | |
| 2020-10-22 19:27 | Kunda1 | Note Added: 0014932 | |
| 2020-10-22 20:27 | Kunda1 | Tag Detached: #post-to-forum | |
| 2020-10-22 20:27 | Kunda1 | Tag Attached: #pending | |
| 2020-10-22 23:08 | kkremitzki | Note Added: 0014937 | |
| 2020-12-12 12:52 | Kunda1 | Note Added: 0015127 | |
| 2021-01-15 23:55 | mrjohnc | Note Added: 0015209 | |
| 2021-02-20 18:01 | Kunda1 | Note Added: 0015392 | |
| 2021-02-20 18:01 | Kunda1 | Tag Attached: #tobeclosed | |
| 2021-02-20 20:39 | Kunda1 | Status | new => closed |
| 2021-02-20 20:39 | Kunda1 | Resolution | open => fixed |
| 2021-02-20 20:39 | Kunda1 | Fixed in Version | => 0.19 |
| 2021-02-20 20:39 | Kunda1 | Note Added: 0015395 | |
| 2021-02-21 10:50 | mrjohnc | Status | closed => feedback |
| 2021-02-21 10:50 | mrjohnc | Resolution | fixed => reopened |
| 2021-02-21 10:50 | mrjohnc | Note Added: 0015407 | |
| 2021-02-21 10:53 | mrjohnc | Note Added: 0015408 | |
| 2021-02-21 10:53 | mrjohnc | Status | feedback => new |
| 2021-02-21 10:53 | mrjohnc | Note Edited: 0015408 | |
| 2021-02-21 10:54 | mrjohnc | Note Edited: 0015408 | |
| 2021-02-21 10:57 | mrjohnc | Note Edited: 0015408 | |
| 2021-02-21 11:36 | Kunda1 | Note Added: 0015412 | |
| 2021-02-21 11:37 | Kunda1 | Note Edited: 0015412 | |
| 2021-02-21 11:42 | Kunda1 | Note Edited: 0015412 | |
| 2021-02-21 11:56 | Kunda1 | Tag Detached: #pending | |
| 2021-02-21 11:56 | Kunda1 | Target Version | 0.20 => 0.19 |
| 2021-02-23 11:00 | yorik | Target Version | 0.19 => 0.20 |
| 2021-03-13 21:29 | Kunda1 | Assigned To | => Kunda1 |
| 2021-03-13 21:29 | Kunda1 | Status | new => resolved |
| 2021-03-13 21:29 | Kunda1 | Resolution | reopened => fixed |
| 2021-03-13 21:29 | Kunda1 | Note Added: 0015507 | |
| 2021-03-13 21:29 | Kunda1 | Tag Detached: #tobeclosed |
