| 0000446 | FreeCAD | Bug | public | 2011-10-07 13:20 | 2011-10-09 00:28 |
| Reporter | unauthenticated | Assigned To | yorik | ||
| Summary | 0000446: Running the Python command 'Draft_Line' failed | ||||
| Description | Running Debian Sid FreeCAD from the repos version 0.11.4446. Whenever I try to draw any lines I get the following: Running the Python command 'Draft_Line' failed: Traceback (most recent call last): File "/usr/lib/freecad/Mod/Draft/draftTools.py", line 1077, in Activated Creator.Activated(self,"Line") File "/usr/lib/freecad/Mod/Draft/draftTools.py", line 1036, in Activated rot = self.view.getCameraNode().getField("orientation").getValue() | ||||
IMO 4446 is quite old version. If you can try something more up-to-date (eg. compile from SVN) http://sourceforge.net/apps/mediawiki/free-cad/index.php?title=Download Bug is probably fixed in newer version. Kwahoo |
This is a pretty strange error, but indeed has probably been fixed a long time ago. I'll close this report because it makes no sense looking deeper a it, so many other things have changed since 0.11 and 0.12 is about to come out anyway, but feel free to reopen if you want to investigate further and try to find a workaround. |
| 2011-10-07 13:20 | unauthenticated | New Issue | |
| 2011-10-08 13:17 | unauthenticated | Note Added: 0001141 | |
| 2011-10-09 00:24 | yorik | Status | new => assigned |
| 2011-10-09 00:24 | yorik | Assigned To | => yorik |
| 2011-10-09 00:28 | yorik | Note Added: 0001142 | |
| 2011-10-09 00:28 | yorik | Status | assigned => closed |
| 2011-10-09 00:28 | yorik | Resolution | open => no change required |
