| 0004467 | Sketcher | Bug | public | 2020-10-18 20:46 | 2021-02-06 06:48 |
| Reporter | TedM | Assigned To | |||
| Summary | 0004467: Cloning and placing to automatically constrain to old objects creates malformed constraints | ||||
| Description | Referencing this thread. Creating a circle and connected line and then cloning these and placing the clone to automatically constrain to original objects generates a malformed constraint. I have reproduced this as far beck as 0.19.21125 which is the earliest 0.19 I have. I cannot reproduce this on 0.18.4, possibly because the automatic constrain on clone placement doesn't work. | ||||
| Steps To Reproduce | 1. Start FreeCAD. 2. Open the report view panel at the bottom of the screen. 3. Create a new document. 4. Go to the Part Design WB. 5. Create a body. 6. Create a sketch on the XY plane. 7. Place a circle, not constrained in location and constrain the radius to 2.5mm. 8. Place a line with one end constrained to the center of the circle and the other end to the right. Add a horizontal constraint and a length constraint of 14mm. 9. Select both objects and then slowly double-click the center of the circle so that everything is still selected and the circle center is last selected. 10. Clone the objects and use the mouse to move the clone reference point onto the right end of the line so that the constrained constraint symbol (a circle on a diagonal cross) shows to make the cloned circle constrained to the old line and click the mouse button. 11. These errors will immediately appear in the report window: 12:03:06 Sketcher constraint number 8 is malformed! 12:03:06 Sketch Sketch has malformed constraints! 12:03:06 Sketcher constraint number 8 is malformed! 12:03:06 Sketcher constraint number 8 is malformed! 12:03:06 Sketch Sketch has malformed constraints! In 0.18.4, step 10 above still shows the constrained constraint symbol (just a dot in that release) but the cloned line and original circle does not constrain. | ||||
| Additional Information | The attached file is the result of the above procedure. | ||||
| FreeCAD Information | OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22665 (Git) Build type: Release Branch: master Hash: b0d7850406e046f3b7a8cd5da261e7d54df6bd99 Python version: 3.8.6 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.4.0 Locale: English/United States (en_US) | ||||
So, small error in procedure. Step 10 should read: 10. Clone the objects and use the mouse to move the clone reference point onto the right end of the line so that the constrained constraint symbol (a circle on a diagonal cross) shows to make the cloned circle constrained to the old line and |
@TedM : I fixed the typo in the original text according your note ;) |
This ticket has been migrated to GitHub as issue 6116. |
| 2020-10-18 20:46 | TedM | New Issue | |
| 2020-10-18 20:46 | TedM | File Added: malformed constraints created.FCStd | |
| 2020-10-18 20:49 | TedM | Note Added: 0014910 | |
| 2020-10-21 15:49 | openBrain | Status | new => acknowledged |
| 2020-10-21 15:49 | openBrain | Description Updated | |
| 2020-10-21 15:49 | openBrain | Steps to Reproduce Updated | |
| 2020-10-21 15:49 | openBrain | FreeCAD Information | OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22665 (Git) Build type: Release Branch: master Hash: b0d7850406e046f3b7a8cd5da261e7d54df6bd99 Python version: 3.8.6 Qt version: 5.12.9 Coin version: 4.0.0 OCC vers... => OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22665 (Git) Build type: Release Branch: master Hash: b0d7850406e046f3b7a8cd5da261e7d54df6bd99 Python version: 3.8.6 Qt version: 5.12.9 Coin version: 4.0.0... |
| 2020-10-21 15:50 | openBrain | Note Added: 0014919 | |
