| 0004478 | Sketcher | Bug | public | 2020-10-29 17:04 | 2020-11-09 18:08 |
| Reporter | chennes | Assigned To | abdullah | ||
| Summary | 0004478: Active constraint tool blocks sidebar tasks from working | ||||
| Description | If a constraint tool is active, various commands in the Task sidebar that appear to be available are blocked from working. For example, the text "click to select" in the Solver's redundant constraint message is unresponsive, although it appears clickable. Constraint right click menu options such as "Delete" also do nothing. No error is reported when selecting them: nothing happens at all. | ||||
| Steps To Reproduce | This comes up particularly when your workflow is to select the constraint operation first, and then click on the elements needed for the constraint. If this results in a redundant constraint you'd probably like to address that immediately, but clicking on the "click to select" text does nothing. So, e.g.:
| Additional Information | Basically, any command that requires a check through isSketcherAcceleratorActive() does not work when a Constraint operation is active, and is silently cancelled by the condition that requires that Mode == ViewProviderSketch::STATUS_NONE. In the forums discussion (https://forum.freecadweb.org/viewtopic.php?f=3&t=51555) chrisb suggests: "It should behave in the same way as when selecting a different geometric constraint or a geometric element creation icon: the previously selected function is cancelled immediately." | ||||
| FreeCAD Information | OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22865 (Git) Build type: Debug Branch: master Hash: 3c307b7a3c222d66cb70695cdcf79606553fcb91 Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United States (en_US) | ||||
FreeCAD: master c23e1dd7 2020-11-05 22:53:08 Committer: abdullahtahiriyo Details Diff |
Release handler in commands where not needed Fixes 0004478: Active constraint tool blocks sidebar tasks from working. Many commands are interrupted by the existence of a handler. Rather than having these commands silently cancel, purge the handler if a command executes that does not need it. When right-clicking on an item in the Constraint Task sidebar, any current operation is cancelled and the FreeCAD selection is synced with the selected items in the constraints QListWidget. This allows all of the menu items in the context menu to function properly: if the selection is not synced, anything that relies on the FreeCAD selection (like Delete) will sillently fail. |
Affected Issues 0004478 |
| mod - src/Mod/Sketcher/Gui/CommandConstraints.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/CommandConstraints.h | Diff File | ||
| mod - src/Mod/Sketcher/Gui/CommandSketcherTools.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/TaskSketcherConstrains.cpp | Diff File | ||
| 2020-10-29 17:04 | chennes | New Issue | |
| 2020-10-29 17:08 | chennes | Additional Information Updated | |
| 2020-10-29 17:53 | openBrain | Status | new => acknowledged |
| 2020-10-29 17:53 | openBrain | Additional Information Updated | |
| 2020-11-07 19:30 | chennes | Changeset attached | => FreeCAD master c23e1dd7 |
| 2020-11-07 19:30 | guest | Note Added: 0014964 | |
| 2020-11-09 18:04 | abdullah | Assigned To | => abdullah |
| 2020-11-09 18:04 | abdullah | Status | acknowledged => resolved |
| 2020-11-09 18:04 | abdullah | Resolution | open => fixed |
| 2020-11-09 18:04 | abdullah | Fixed in Version | => 0.19 |
| 2020-11-09 18:04 | abdullah | Note Added: 0014969 | |
| 2020-11-09 18:08 | abdullah | Status | resolved => closed |
