| 0000448 | FreeCAD | Feature | public | 2011-10-12 12:29 | 2014-03-11 02:09 |
| Reporter | aguseguedre | Assigned To | |||
| Summary | 0000448: Snap in the circle, cylinder center | ||||
| Description | For centrer holes in a object or measure the distance between the corner of the object and circle is more easy and accurate if the centre of circle Snap too. | ||||
2011-10-12 12:29
Not totally sure what you mean... Is it the Draft snap you mean? (used in Draft functions such as move or rotate)? For me it works OK (you must press CTRL and you must be on the circle that borders the top face) If you mean the Sketcher snap, at the moment it is still not possible to snap to other objects, but it is planned... |
Oh I see... Just read the discussion on http://forum.freecadweb.org/viewtopic.php?f=3&t=1542&start=10 I suppose that will have to wait for further development... Once the sketcher will gain ability to put constraints between different objects, I'm sur that case will be adressed. |
Will close this for now since no action is required, reopen if needed. |
| 2011-10-12 12:29 | aguseguedre | New Issue | |
| 2011-10-12 12:29 | aguseguedre | File Added: Pantallazo-1.png | |
| 2011-10-12 19:56 | yorik | Note Added: 0001143 | |
| 2011-10-12 20:11 | yorik | Note Added: 0001145 | |
| 2014-03-11 02:09 | yorik | Note Added: 0004419 | |
| 2014-03-11 02:09 | yorik | Status | new => closed |
| 2014-03-11 02:09 | yorik | Resolution | open => no change required |
