0004480ExpressionsBugpublic2021-02-06 06:30
Reportermapeze Assigned To
Status newResolutionopen
Target Version0.20
Summary0004480: Cross-document linking does not update on Recompute
DescriptionHello,
This Bug report refers to the discussion https://forum.freecad.org/viewtopic.php?f=8&t=51594&p=443097#p443097
The cross-document linking feature stopped working properly from an unspecified 0.19 version and above. I have detected the issue in the Spreadsheets only (I have never been able to make the cross-document linking work outside the Spreadsheet environment). The cross-document linkng feature is described here: https://wiki.freecad.org/Expressions
The expected behaviour of the cross-document linking, as it was working in FreeCAD old versions is:
- Having one Master file with a Spreadheet inside, an alias and a value is given to a cell
- Having a Slave file with a Spreadsheet inside, an expression is given to a cell with the expression "=Master_file_name#Master_Spreadsheet_name.alias_name"
- The value of the Master cell is changed
- The value of the slave cell is updated when Recompute action is done.
However in new Freecad versions, to update the slave cell value one of the next two actions is needed:
- Enter the slave cell to edit it, leave it as it is and press Enter
- Reopen the slave file
Steps To Reproduce1- Open the attached Master.FCStd and Slave.FCStd files in this order
2- Open the Spreadsheet on Master file and change the B1 cell value to something diferent
3- Open the Spreadsheet on the Slave file and press the Recompute button on the toolbar
4- The B1 cell on Slave's Spreadsheet should be updated, but it is not.
FreeCAD InformationOS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.19.22846 (Git) AppImage
Hash: 1f46b72491a0008384a6db4f2615a656249f6f08
Python version: 3.8.6
mapeze
2020-10-30 07:54
reporter
Slave.FCStd (1,866 bytes)
Master.FCStd (1,783 bytes)
yorik
2022-03-03 13:55
administrator   ~0016956
This ticket has been migrated to GitHub as issue 6123.
2020-10-30 07:54 mapeze New Issue
2020-10-30 07:54 mapeze File Added: Slave.FCStd
2020-10-30 07:54 mapeze File Added: Master.FCStd
2021-02-06 06:30 abdullah Target Version => 0.20
