| 0004482 | FreeCAD | Feature | public | 2020-11-02 11:52 | 2021-02-06 06:49 |
| Reporter | Pauvres_honteux | Assigned To | |||
| Summary | 0004482: Create point on plane while at the same time beeing connected to another point in/on the same plane. | ||||
| Description | Point on plane with respect to another point As of 2020-11-02 it is not possible to create a point on a plane while at the same time being connected to another point on that plane. | ||||
| Steps To Reproduce | In Part: - Create 1:st point, to be used as master point. - Create 2:nd point and connect it to the first point by typing Vertex(vertex number here).Placement.Base.x Repeat for Y and Z. Set "Attachment offset" to [20,0,0]. - Create 3:rd point and connect it to the first point by typing Vertex(vertex number here).Placement.Base.x Repeat for Y and Z. Set "Attachment offset" to [0,30,0]. - Create 4:th point and connect it to the first point by typing Vertex(vertex number here).Placement.Base.x Repeat for Y and Z. Set "Attachment offset" to [0,0,40]. - Create a plane_1 passing through point 1, 2 and 3. - Create a plane_2 passing through point 1, 3 and 4. - Create a plane_3 passing through point 1, 4 and 2. - Create a point on one of the planes and try to connect it to point 1 -> does not work. ______________________________________________________________________ In PartDesign: - Create 1:st (Datum)point, to be used as master point. - Create 2:nd (Datum)point and connect it to the first point by choosing "Support" = (Datum)point 1 and Map Mode = Vertex. Set "Attachment" = [20,0,0] - Create 3:rd (Datum)point and connect it to the first point by choosing "Support" = (Datum)point 1 and Map Mode = Vertex. Set "Attachment" = [0,30,5] - Create 4:th (Datum)point and connect it to the first point by choosing "Support" = (Datum)point 1 and Map Mode = Vertex. Set "Attachment" = [-10,-15:40] - Create a plane_1 passing through point 1, 2 and 3 ("Map Mode" 'ThreePointsPlane'). - Create a plane_2 passing through point 1, 3 and 4. ("Map Mode" 'ThreePointsPlane') - Create a plane_3 passing through point 1, 4 and 2. ("Map Mode" 'ThreePointsPlane') - Create a point on one of the planes and try to connect it to point 1 -> does not work. | ||||
| FreeCAD Information | OS: openSUSE Leap 15.1 (KDE//usr/share/xsessions/default) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.Unknown Build type: Release Python version: 3.6.5 Qt version: 5.9.7 Coin version: 4.0.0 OCC version: 7.5.0.beta | ||||
| 2020-11-02 11:52 | Pauvres_honteux | New Issue | |
