| 0004494 | PartDesign | Bug | public | 2020-11-14 09:15 | 2021-02-24 09:55 |
| Reporter | chrisb | Assigned To | wmayer | ||
| Summary | 0004494: Error "Result is empty" for Pads and Pockets with non zero Offset | ||||
| Description | In some cases Pad offset does nothing in others it works. I couldn't find out the criteria. In the corresponding forum post I have attached an example. Steps to reproduce: - load the file PadOffset.FCStd - double click Pad001 - change Type to one of ToFirst, ToLast, UpToFace - if changed to UpToFace select one of the faces parallel to the sketch, e.g. the selected face in the post. - change offset to 10, any other value <0 or >0 will do as well - confirm: error "Pad: Result is empty" occurs Same behaviour is shown if the changes are made without the dialog directly in the Data tab. | ||||
| FreeCAD Information | OS: macOS High Sierra (10.13) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22960 (Git) Build type: Release Branch: master Hash: c5a4b01d2e4218bcc0eb6650337650a6c65ef0e4 Python version: 3.8.6 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
https://github.com/wwmayer/FreeCAD/tree/fix_offset_in_pad_or_pocket |
I can observe the behaviour with a pad but not with a pocket. The reason for the problem is if the Fuse parameter of BRepFeat_MakePrism is set to 2 when an offset is set. Both of the values 2 and 1 does a fusion while for 0 a cut is done that is used by the pocket. The solution (at least in this case) is to use the value 1 if at the same time an offset is used. |
| 2020-11-14 09:15 | chrisb | New Issue | |
| 2020-11-16 12:52 | wmayer | Note Added: 0014992 | |
| 2020-11-16 13:44 | wmayer | Note Added: 0014993 | |
| 2020-11-16 14:00 | wmayer | Changeset attached | => FreeCAD master 42ccdb81 |
| 2020-11-16 14:00 | wmayer | Note Added: 0014994 | |
| 2020-11-16 14:00 | wmayer | Assigned To | => wmayer |
| 2020-11-16 14:00 | wmayer | Status | new => closed |
| 2020-11-16 14:00 | wmayer | Resolution | open => fixed |
| 2021-02-24 09:55 | wmayer | Relationship added | related to 0004567 |
