| 0000450 | FreeCAD | Patch | public | 2011-10-19 04:23 | 2011-10-21 13:12 |
| Summary | 0000450: new Icons for Part Work Bench, Ruled Surface, Shape Info, and Create Primitives | ||||
| Description | I have created three Icons for Part Work Bench, 1)Ruled Surface, 2)Shape Info, and 3)Create Primitives | ||||
| Additional Information | I believe these Icons are good enough to be (at least) better than nothing. I suggest we include them for now and simply replace them in the future if someone comes up with something better. I have included the modified associated files .... Workbench.cpp, Command.cpp, Part.qrc, as well as the three svg Part icon files ..... CreatePrimitives, ShapeInfo, and RuledSurface.svg in the zip archives attached | ||||
2011-10-19 04:23
2011-10-20 16:12
The newer zip archive now contains diff files for the changed files and complete files for the new files. I have not yet got diff to behave well enough to get a single patch yet. Sorry for the inconvenience. |
you don't need to diff every single file. You can put the diffs of all files to a single file. Simply use this in the FreeCAD root directory: svn diff > mypatch.diff |
Done in r5047 |
| 2011-10-19 04:23 | jmaustpc | New Issue | |
| 2011-10-19 04:23 | jmaustpc | File Added: PartWorkBench_added_ruledsurface_ShapeInfo_and_CreatePrimatives_icons_to_toolbars_and_menus_in_Part_Workbench.zip | |
| 2011-10-20 16:12 | jmaustpc | File Added: new_icons_Partinfo_RuledSurface_CreatePrimatives.zip | |
| 2011-10-20 16:16 | jmaustpc | Note Added: 0001177 | |
| 2011-10-21 12:55 | wmayer | Note Added: 0001179 | |
| 2011-10-21 13:12 | wmayer | Note Added: 0001180 | |
| 2011-10-21 13:12 | wmayer | Status | new => closed |
| 2011-10-21 13:12 | wmayer | Resolution | open => fixed |
| 2011-10-21 13:12 | wmayer | Fixed in Version | => 0.12 |
