| 0000453 | FreeCAD | Bug | public | 2011-10-21 09:32 | 2014-10-27 13:06 |
| Reporter | wmayer | Assigned To | yorik | ||
| Summary | 0000453: Untranslated strings | ||||
| Description | http://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=10&t=1800 | ||||
strings were extracted from source today and added to crowdin. I believe there will be not much missing until the 0.12 release... |
http://forum.freecadweb.org/viewtopic.php?f=8&t=1234&sid=29f25110b85daf31d8a3d2ff19ae7c91&start=60#p11682 |
A list of strings that are not considered by the translation system (from http://forum.freecadweb.org/viewtopic.php?f=10&t=1800&p=11798#p11778 ) View Window: Unnamed (The project file name in the view tab) Close tab (view tab close button) Panels: All the values name and valor (Display tab) All the values name and valor (Data tab) File Menu: File type list (Dropdown list in file open dialog) File type list (Dropdown list in file import dialog) File type list (Dropdown list in merge project dialog) Unknown (Project information -> Las modification date) All the buttons and tooltips (Print Preview window) Preferences window: Dropdown module name list (General -> General -> Start group) View smoothing (Part design) Hint (Part design) Edit Menu: Buttons (Placements.. task panel) View Menu: Close (Texture mapping... task panel) Display properties (Display properties window title) display dropdown list (Display properties window) Material dropdown list (Display properties window) Workbenches (Workbench) Sketcher geometries (Toolbars) Tools Menu: File type dropdown list (Save picture... window) Cancel button (Save picture... window) Help Menu: Everything (Help) Everything (About Qt) Test framework: Everything (Toolbar) Everything (Test Command menu) Inventor View (Menu) Web: Everything (Toolbar) Sketcher: Close button (Panel) Help button (Panel) Part Design: Cancel button (Chamfer panel) Part: Close button (Boolean operation panel) Apply button (Boolean operation panel) Cancel button (Section panel) Apply button (Section panel) Cancel button (Extrude panel) Apply button (Extrude panel) Cancel button (Revolve panel) Cancel button (Mirroring panel) Cancel button (Fillet panel) Shape info (Part menu) Shape info (Status bar) Robot: Cancel button (Edge to trajectory panel) Apply button (Edge to trajectory panel) TaskEdge2TracParameter (Edge to trajectory panel) Edges (Edge to trajectory panel) Cluster (Edge to trajectory panel) Mesh Design: Evaluate & Repair Mesh (Evaluate & Repair Mesh panel title) Inspection: Everything (Inspection menu) Everything (Visual inspection window) |
I'll assign this to myself... Not sure I can handle the untranslated strings, but I'll take care of updating and pulling the translations to/from crowdin. |
Since v012 is basically done, I changed issue priority and title from "Update translation for v0.12" to "Untranslated strings" |
Only points missing above where something should still be done: 1) The label of a default new document (Unnamed) should be translated. But this is decided in App, where Qt is not present. Not sure how to solve this... Werner do you have an idea about this? 2) The Web WB has no translations file. I'll take care of it... |
Qt is already sparsely used in Base and App. But adding the whole translation system to App for just a couple of strings is overkill. So, I think we can keep it quite simple: Put this into e.g. Gui/Document.cpp: #if 0 // needed for Qt's lupdate utility qApp->translate("App::Document", "Unnamed"); #endif Then inside Application::sNewDocument: QString name = QCoreApplication::translate("App::Document", "Unnamed"); and if "usrName" there is not set from outside we can pass the translated string: if (usrName) return GetApplication().newDocument(docName, usrName)->getPyObject(); else return GetApplication().newDocument(docName, name.toUtf8().constData())->getPyObject(); |
Finally the fix was simple, the translation is already handled by the StdCmdNew command... I just made a little change, that is the document label is taken from the name passed to the command, not the unique name chosen by FreeCAD. |
FreeCAD: master 6e5fbc74 2014-09-18 17:24:16 Details Diff |
Added base translation file for the Web WB - issue 0000453 |
Affected Issues 0000453 |
| add - src/Mod/Web/Gui/Resources/translations/Web.ts | Diff File | ||
| mod - src/Tools/updateTranslations.py | Diff File | ||
FreeCAD: master fbeb7beb 2014-09-19 01:17:50 Details Diff |
Fixed label of document - fixes 0000453 |
FreeCAD: master 429e55d7 2014-10-27 13:11:50 Details Diff |
+ make sure to set unique labels for newly created documents |
| 2011-10-21 09:32 | wmayer | New Issue | |
| 2011-10-22 00:22 | yorik | Note Added: 0001182 | |
| 2011-10-22 12:13 | wmayer | Note Added: 0001185 | |
| 2011-10-24 13:05 | yorik | Note Added: 0001188 | |
| 2011-11-24 01:09 | yorik | Note Added: 0001346 | |
| 2011-11-24 01:10 | yorik | Status | new => assigned |
| 2011-11-24 01:10 | yorik | Assigned To | => yorik |
| 2011-11-24 01:18 | yorik | Priority | normal => urgent |
| 2011-12-05 13:01 | yorik | Note Added: 0001391 | |
| 2011-12-05 13:01 | yorik | Priority | urgent => normal |
| 2011-12-05 13:01 | yorik | Target Version | => 0.13 |
| 2011-12-05 13:01 | yorik | Summary | Update translation for v0.12 => Untranslated strings |
| 2014-07-06 15:27 | yorik | Target Version | 0.13 => 0.15 |
| 2014-09-18 15:00 | yorik | Note Added: 0005126 | |
| 2014-09-18 15:50 | yorik | Changeset attached | => FreeCAD Master master 6e5fbc74 |
| 2014-09-18 16:44 | wmayer | Note Added: 0005127 | |
| 2014-09-18 23:21 | yorik | Note Added: 0005129 | |
| 2014-09-18 23:30 | yorik | Changeset attached | => FreeCAD Master master fbeb7beb |
| 2014-09-18 23:30 | yorik | Status | assigned => closed |
| 2014-09-18 23:30 | yorik | Resolution | open => fixed |
| 2014-10-27 13:06 | wmayer | Changeset attached | => FreeCAD Master master 429e55d7 |
