| 0004530 | Sketcher | Feature | public | 2021-01-07 17:55 | 2021-02-06 05:55 |
| Reporter | abdullah | Assigned To | abdullah | ||
| Summary | 0004530: Explore geometry element based block constraint | ||||
| Description | When implementing the new Block constraint, it became clear the constraint has potential for blocking individual elements of a geometry (none, start, end, mid) as opposed to the whole geometry. A cost-benefit analysis is needed for this possibility of extension, which may make sense or not. First the current new Block constraint needs to settle. | ||||
