| 0004537 | FreeCAD | Bug | public | 2021-01-17 18:03 | 2021-02-06 06:49 |
| Reporter | bertrand.lancelot@objectspirit.net | Assigned To | |||
| Summary | 0004537: Export GCode - 'PrimitivePy' object has no attribute 'Proxy' error message | ||||
| Description | OS: MAC Catalina 10.15.7 Freecad version 018.16146 (same problem with install from a download or with brew install) Impossible to export the 3D model to print it with my 3D printer. Anyway the processor used. Then this issue is blocking issue for me. Thanks in advance, but in waiting, I will try another tool to be able to test and use my new 3D printer. | ||||
| Steps To Reproduce | create a symple Cylinder 3D object or anything else in 3D. Go to menu file / export title: test.gc for exemple validate select the first processor in the list "centroid_post" (none is working after many tests) Validate Then the error message appear: Cylinder postprocessing... Traceback (most recent call last): File "<string>", line 4, in <module> <class 'RuntimeError'>: 'PrimitivePy' object has no attribute 'Proxy' | ||||
| FreeCAD Information | to be completed | ||||
Hi, I did find a turnaround in using ultimaker cuba tool. Then, I have to export to obl file and open it in cuba to transform obj file to g-code. A bit longer but acceptable in waiting a fix. So, possible to change priority to low if you want. Regards, |
This ticket has been migrated to GitHub as issue 6150. |
| 2021-01-17 18:03 | bertrand.lancelot@objectspirit.net | New Issue | |
| 2021-01-24 08:02 | bertrand.lancelot@objectspirit.net | Note Added: 0015219 | |
