| 0004540 | FreeCAD | Bug | public | 2021-01-18 22:24 | 2021-02-20 13:00 |
| Reporter | kisolre | Assigned To | wmayer | ||
| Summary | 0004540: When manual size of DatumPlane is selected its Length property is not saved to the file and consequently not restored on opening | ||||
| Description | Forum thread | ||||
| Steps To Reproduce | Create new file, add new body. Add Datum plane. attach to XY plane. Change Resize property of DatumPlane to Manual. Change Length and Width to different values. Save file. Close file. Open file, check DatumPlane Length and Width values - Width is as entered, Length is not. | ||||
| Additional Information | Inspecting the Document.xml shows that there is no entry for Length property. | ||||
| FreeCAD Information | OS: Windows 8.1 Version 6.3 (Build 9600) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.23717 (Git) Build type: Release Branch: master Hash: 254ed951f924687e3dffb325288bbc0333980b9c Python version: 3.8.6+ Qt version: 5.15.1 Coin version: 4.0.1 OCC version: 7.5.0 Locale: Bulgarian/Bulgaria (bg_BG) | ||||
Length is also saved to the project file but the problem is that when reading in the properties it first reads Length, ResizeMode and then Width. Because the default mode is "Automatic" it automatically adjusts Length when reading it in. Afterwards resize mode is set to manual so that when reading in Width it won't changed. |
FreeCAD: master 13ed4bc6 2021-02-20 12:33:54 Details Diff |
PD: [skip ci] fixes 0004540: When manual size of DatumPlane is selected its Length property is not saved to the file and consequently not restored on opening |
Affected Issues 0004540 |
| mod - src/Mod/PartDesign/App/DatumPlane.cpp | Diff File | ||
| mod - src/Mod/PartDesign/App/DatumPlane.h | Diff File | ||
| 2021-01-18 22:24 | kisolre | New Issue | |
| 2021-01-18 22:24 | kisolre | File Added: test datum plane sizes.FCStd | |
| 2021-02-20 12:31 | wmayer | Note Added: 0015373 | |
| 2021-02-20 12:31 | wmayer | Note Edited: 0015373 | |
| 2021-02-20 13:00 | wmayer | Changeset attached | => FreeCAD master 13ed4bc6 |
| 2021-02-20 13:00 | wmayer | Note Added: 0015374 | |
| 2021-02-20 13:00 | wmayer | Assigned To | => wmayer |
| 2021-02-20 13:00 | wmayer | Status | new => closed |
| 2021-02-20 13:00 | wmayer | Resolution | open => fixed |
