0004548ArchBugpublic2021-02-06 06:28
Reporterbalrobs Assigned Topaullee
Status assignedResolutionopen
Target Version0.20
Summary0004548: Arch:Stair - Connection issue between landing and second flight
DescriptionATM using the Arch stair tool to create a HalfTurnLeft/HalfTurnRight stair with a single line as base element leads to a connection result between the landing and the seconf flight that can be improved!
See forum discussion with picture at https://forum.freecadweb.org/viewtopic.php?f=22&t=53018&start=30#p472079
Steps To Reproduce1) model an Arch Stair by creating a single line with a length i.e. 4500mm
2) change to the Arch workbench and select the line
3) press the Arch Stair button to generate an Arch Stair
4) in the Structure properties set Flight = HalfTurnLeft
5) observe the connection between landing and second flight
FreeCAD InformationOS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: 497ecbe0eb399dd2b873762e4406aa9569976870
Python version: 3.8.5
Qt version: 5.12.8
paullee
2021-01-31 18:32
developer   ~0015247
Another similar issue discussed in same thread -
2nd Issue in Post - RC stairs macro
yorik
2022-03-03 13:55
administrator   ~0016986
This ticket has been migrated to GitHub as issue 6154.
2021-01-31 18:08 balrobs New Issue
2021-01-31 18:32 paullee Note Added: 0015247
2021-01-31 18:33 paullee Assigned To => paullee
2021-01-31 18:33 paullee Status new => assigned
2021-02-06 06:28 abdullah Target Version => 0.20
