| 0000455 | FreeCAD | Bug | public | 2011-10-23 20:58 | 2012-01-16 21:55 |
| Summary | 0000455: Import :igs files | ||||
| Description | crash when I try to open .igs files for esampe see:http://www.kurtworkholding.com/downloads/igs/ FreeCAD run on: MS Windows Vista Home Premium 32-bit SP2 AMD Turion 64 X2 Mobile TL-52 | ||||
had the same problem -- resulted in an exception thrown, but it seems that it works under Linux or MacOsx |
The problem is that OpenCasCade (our CAD kernel) can not load that. The header gives a indication why: SolidWorks IGES file using analytic representation for surfaces S 1 1H,,1H;,16HCT2DC4B end_user,77HC:\3D Vise model - end user\CT2DC4B\ct2dcG 1 4b end user\CT2DC4B end-user IGS.IGS,41HSolidWorks 2006 by SolidWorks CoG 2 rporation,41HSolidWorks 2006 by SolidWorks Corporation,32,308,15,308, G 3 15,16HCT2DC4B end_user,1.,1,2HIN,50,0.125,13H060719.073636,1E-008, G 4 19684.6456692913,5HIlyaK,,11,0,13H060719.073636; G 5 Solid works seams to use very uncommon IGES elements. This is a bug report for the OpenCascade project.... |
Thank you very much! (I'm the 'unaunthenticated' ) ---- EXCUSE MY ENGLISH !!!! ---- I open this files correctly with gcad and HeeksCAD but I do not be able to export this files in dxf HELP! THANK'S Solution: Version unstable 0.12.5149 seems open this file ! Thank's |
I tried downloading and opening a few files from that site and indeed all seems to work fine now. I think we can close this... |
| 2011-10-23 20:58 | unauthenticated | New Issue | |
| 2011-10-31 19:32 | jacques2011 | Note Added: 0001202 | |
| 2011-11-04 21:06 |
Note Added: 0001242 | |
| 2011-11-04 21:06 |
Status | new => closed |
| 2011-11-04 21:06 |
Resolution | open => not fixable |
| 2011-11-12 14:35 | unauthenticated | Note Added: 0001280 | |
| 2011-11-12 14:35 | unauthenticated | Status | closed => feedback |
| 2011-11-12 14:35 | unauthenticated | Resolution | not fixable => reopened |
| 2011-11-20 18:09 | unauthenticated | Note Edited: 0001280 | |
| 2012-01-16 21:55 | yorik | Note Added: 0001585 | |
| 2012-01-16 21:55 | yorik | Status | feedback => closed |
| 2012-01-16 21:55 | yorik | Resolution | reopened => fixed |
| 2012-01-16 21:55 | yorik | Fixed in Version | => 0.13 |
