0004594FreeCADBugpublic2021-05-23 14:55
Reporterdudo Assigned To
Status newResolutionopen
PlatformArch LinuxOSLinux
Product Version0.20
Summary0004594: Grid is transparent in respect to the window
DescriptionGrid lines, instead of being filled with color, are filled with whatever is "below" the FreeCAD window, eg. desktop wallper, other windows, etc.
https://forum.freecad.org/viewtopic.php?f=3&t=56509
https://streamable.com/4xedi5
https://i.imgur.com/dVKiDaB.png
Additional InformationThis is using fully up to date Arch Linux, using git version of FreeCAD, running under wayland / sway
TagsCoin3d
FreeCAD InformationOS: Arch Linux
Version: 0.20.24407 (Git)
Hash: 9f937f765d9c811535018110618056883b258837
Python version: 3.9.2
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
dudo
2021-03-11 01:16
reporter   ~0015498
It seems to be related to blending, like every mesh that's rendered with some kind of transparency shows the bug in action
https://streamable.com/0qavx3
(Additionally, note the z-fighting issues, unrelated I guess)
dudo
2021-03-11 17:34
reporter   ~0015499
On the same system under Xorg it works all right, no transparency issues, so this could be wayland specific
2021-03-11 19:47
administrator   ~0015501
What graphics card/display driver are you using? Have you read the known issues as chrisb mentions in the forum thread?
dudo
2021-03-12 01:18
reporter   ~0015502
I've read the known issues but couldn't find any that would describe this behavior. The driver is Intel/MESA.
~> glxinfo | grep OpenGL
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 4000 (IVB GT2)
OpenGL core profile version string: 4.2 (Core Profile) Mesa 20.3.4
OpenGL core profile shading language version string: 4.20
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.0 Mesa 20.3.4
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 20.3.4
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
OpenGL ES profile extensions:
~> lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
dannixon
2021-03-29 17:02
reporter   ~0015576
I am also seeing this issue using FreeCAD 0.19.
It happens with both Weston and wlroots based compositors and not at all under Xorg/Xwayland.
I'll also add that setting a solid background color also causes the entire render area to be affected, not just transparent areas.
I do notice the following error which is only seen when running under Wayland:
Coin warning in glxglue_isdirect(): Couldn't get current GLX context.
skewty
2021-05-23 14:43
reporter   ~0015675
This also affects Fedora 34 Gnome so Platform field should perhaps be adjusted accordingly.
What I see in Fedora 34 is the part background color, when set to solid is completely transparent. Oddly this does not occur on the gradient setting.
A work-around for this is thus to set both gradient colors to be the same (looks like a solid color but isn't transparent).
I am also getting odd Qt menu placement issues in Wayland. For example:
  • File menu opens to the left outside window bounds.
  • Edit menu opens to the top outside window bounds.
Additionally the splash screen is not centered when it opens for me.
Could these all be related to a screen size / boundary call (upstream in Qt most likely) not working correctly in Wayland?
skewty
2021-05-23 14:55
reporter   ~0015676
[scott@fedora ~]$ glxinfo | grep OpenGL
OpenGL renderer string: Mesa Intel(R) UHD Graphics (CML GT2)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 21.1.1
OpenGL core profile shading language version string: 4.60
OpenGL version string: 4.6 (Compatibility Profile) Mesa 21.1.1
OpenGL shading language version string: 4.60
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.1.1
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
[scott@fedora ~]$ lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation CometLake-U GT2 [UHD Graphics] (rev 02)
[scott@fedora ~]$
yorik
2022-03-03 13:55
administrator   ~0017009
This ticket has been migrated to GitHub as issue 6177.
2021-03-10 20:31 dudo New Issue
2021-03-10 20:33 dudo Tag Attached: Coin3d
2021-03-11 01:16 dudo Note Added: 0015498
2021-03-11 17:34 dudo Note Added: 0015499
2021-03-11 19:47 Kunda1 Note Added: 0015501
2021-03-11 19:47 Kunda1 Status new => feedback
2021-03-11 19:48 Kunda1 Note Edited: 0015501
2021-03-12 01:18 dudo Note Added: 0015502
2021-03-12 01:18 dudo Status feedback => new
2021-03-29 17:02 dannixon Note Added: 0015576
2021-05-23 14:43 skewty Note Added: 0015675
2021-05-23 14:55 skewty Note Added: 0015676
