| 0004606 | PartDesign | Bug | public | 2021-03-25 06:08 | 2021-03-27 11:47 |
| Reporter | jhelmine | Assigned To | |||
| Summary | 0004606: Part Design Pad tool do not work in linux AppImage 24212 works in Windows 0.20 24489 (git) | ||||
| Description | Hello, Example were padding do not work in prebuild 24212 Linux version but works on Windows, compiled from git 24489. Test file in http://jhelmine.kapsi.fi/3D/LedKehysVaunuun_test.FCStd (same included to report also). | ||||
| Steps To Reproduce | To repeat error open file LedKehysVaunuun_test.FCStd. First use "Part Design" then activate Body001Yläpallo. Click Sketch006RuuvinRunko and click Pad this sketch. Padding to normal direction do not show anything else than outlines in already made body. Reverse direction padding adds structure. Windows version (0.20 from master) works as expected and I can continue. Before error situation parameters in spreadsheet ("data") was changed and paddings and pockets removed. Changing data.PallonD (text "Pallon halkaisija") to small value like 50 or less makes error situation, multiple bodies. This was done before error but correcting to back do not help. | ||||
| Additional Information | Padding tested in: FreeCAD_0.19-24212-Linux-Conda_glibc2.12-x86_64.AppImage FreeCAD_0.19-23578-Linux-Conda_glibc2.12-x86_64.AppImage | ||||
| Tags | #pending-forum, appimage | ||||
| FreeCAD Information | OS: Ubuntu 20.10 (ubuntu:GNOME/ubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.24212 (Git) AppImage Build type: Release Branch: master Hash: 3d227cf7179c00e57f2733f947b4b1b0368d219a Python version: 3.8.6 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: Finnish/Finland (fi_FI) | ||||
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=57132 |
Per @looo this looks like a discrepancy between OCCT 7.4.0 and 7.5.0 |
This ticket has been migrated to GitHub as issue 6184. |
| 2021-03-25 06:08 | jhelmine | New Issue | |
| 2021-03-25 06:08 | jhelmine | File Added: LedKehysVaunuun_test.FCStd | |
| 2021-03-27 10:23 | Kunda1 | Tag Attached: appimage | |
| 2021-03-27 10:25 | Kunda1 | Note Added: 0015551 | |
| 2021-03-27 10:25 | Kunda1 | Tag Attached: #pending-forum | |
| 2021-03-27 11:47 | Kunda1 | Note Added: 0015556 |
