| 0004607 | PartDesign | Bug | public | 2021-03-26 18:56 | 2021-12-06 23:13 |
| Reporter | drmacro | Assigned To | jnxd | ||
| Platform | PC | OS | Linux | OS Version | Ub20.04, Deb10 |
| Summary | 0004607: Can't loft to a Point object in Part Design | ||||
| Description | This is the same in 0.19 and 0.20 With either a point (toggled to real geometry) in a sketch or a Draft Point you can loft in Part workbench. (Thus creating a pyramid) But, error is thrown if attempt is made in Part Design. | ||||
| Steps To Reproduce | Switch to Part Design WB Create a sketch, on XY_Plane, with a rectangle, close sketch Create another sketch, on XY_Plane, offset in Z, create a point (point is created by default as reference geometry)toggle point to real geometry Close sketch. Select sketches and attempt to loft. Error: Loft: Sections need to have same amount of inner wires as the base section. This is inconsistent since it works in Part WB. | ||||
| FreeCAD Information | OS: Ubuntu 20.04.2 LTS (XFCE/ubuntustudio) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.20.24498 Build type: Unknown Branch: master Hash: 148c528b09c40c302ac5edaff9f2659935094f5c Python version: 3.8.5 Qt version: 5.12.8 Coin version: 4.0.0 OCC version: 7.5.1 Locale: English/United States (en_US) | ||||
Forum thread: https://forum.freecad.org/viewtopic.php?f=19&t=63697 |
Feature added in https://github.com/FreeCAD/FreeCAD/pull/5170 |
| 2021-03-26 18:56 | drmacro | New Issue | |
| 2021-11-09 18:21 | jnxd | Assigned To | => jnxd |
| 2021-11-09 18:21 | jnxd | Status | new => assigned |
| 2021-11-13 00:09 | jnxd | Target Version | => 0.20 |
| 2021-11-13 01:04 | jnxd | Note Added: 0016026 | |
| 2021-12-06 19:27 | jnxd | Note Added: 0016063 | |
| 2021-12-06 19:28 | jnxd | Status | assigned => resolved |
| 2021-12-06 19:28 | jnxd | Resolution | open => fixed |
| 2021-12-06 23:13 | wmayer | Status | resolved => closed |
| 2021-12-06 23:13 | wmayer | Fixed in Version | => 0.20 |
