| 0000463 | FreeCAD | Bug | public | 2011-11-01 12:23 | 2011-11-02 09:55 |
| Reporter | tilas | Assigned To | |||
| Summary | 0000463: a pad fails to produce a valid solid from a valid sketch | ||||
| Description | a pad fails when the sketch defines a non-simply-connected region | ||||
2011-11-01 12:23
I created a sketch similar to that in the picture and there it works. I used version 0.12 build 5082. Just in case can you upload your project here so that I can also test this one? |
well, unfortunately, I did not save the project. I have tried to reproduce the bug, but now it works as expected. I use the build 5076 on win7x64. Puzzling. |
2011-11-01 14:11
got it! |
OCC fails to create a correct shape. Afterwards the shape healing algorithm must be performed to fix it. Done in rev 5086 |
| 2011-11-01 12:23 | tilas | New Issue | |
| 2011-11-01 12:23 | tilas | File Added: bug.png | |
| 2011-11-01 13:11 | wmayer | Note Added: 0001208 | |
| 2011-11-01 13:55 | tilas | Note Added: 0001209 | |
| 2011-11-01 14:11 | tilas | File Added: test2.FCStd | |
| 2011-11-01 14:13 | tilas | Note Added: 0001210 | |
| 2011-11-02 09:55 | wmayer | Note Added: 0001213 | |
| 2011-11-02 09:55 | wmayer | Status | new => closed |
| 2011-11-02 09:55 | wmayer | Resolution | open => fixed |
| 2011-11-02 09:55 | wmayer | Fixed in Version | => 0.12 |
