| 0004641 | Sketcher | Feature | public | 2021-04-24 12:14 | 2021-04-24 12:14 |
| Reporter | jmaustpc | Assigned To | abdullah | ||
| Summary | 0004641: Sketcher Clone - extend to allow substitution of dimensional constraints between different geometry items | ||||
| Description | Sketcher Clone will currently substitute a dimensional constraint on a single geometry element with a "equals" constraint on the matching geometry element in the clone. The request is to extend this so that it will work when that dimensional constraint is between two different geometry elements. | ||||
| Steps To Reproduce | For example a Horizontal distance constraint applied to the top line of a rectangle will be an Equals constraint on the top line of the rectangle in the clone. However currently if the horizontal distance constraint for the same rectangle was applied between each of the top points of the two vertical side lines of the rectangle, then the same Horizontal constraint will be applied to the clone rectangle rather than an equals, therefore requiring editing every instance of the clone and original if an edit is required. Forum topic https://forum.freecadweb.org/viewtopic.php?f=3&t=57915 An example file is attached to this ticket, it is the same file as one of the files in my post to that same topic in the link above. | ||||
| FreeCAD Information | OS: Ubuntu 20.04.2 LTS (KDE/plasma) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.Stable PPA Build type: Release Branch: unknown Hash: 9e3b630bbfb6807e93eeffb655e6c20f218644fc Python version: 3.8.5 Qt version: 5.12.8 Coin version: 4.0.0 OCC version: 7.5.1 Locale: English/Australia (en_AU) | ||||
