| 0004647 | Path | Bug | public | 2021-04-28 15:23 | 2021-09-03 22:19 |
| Reporter | dubstar_04 | Assigned To | russ4262 | ||
| Summary | 0004647: [Path] - Releative location of Toolbit files | ||||
| Description | It's currently not possible to create a toolbit library using relative paths. This means that is not possible to share libraries between machines / different OS' https://github.com/FreeCAD/FreeCAD/blob/master/src/Mod/Path/PathScripts/PathToolBit.py#L107-L117 https://forum.freecad.org/viewtopic.php?f=15&t=58174&sid=5c2c7fda248c0380c556a4813e7f749b | ||||
| Steps To Reproduce | 1. Delete FreeCAD config 2. Create completely new tool library in an empty directory 3. Create a toolbit 4. check fctl and tctb | ||||
Forum Link: https://forum.freecad.org/viewtopic.php?f=15&t=58174&sid=3d0acf6eccb83839ec06242a3d5469f7 |
PR #4906 contains a possible fix for this issue. |
@dubstar_04, @sliptonic Has this issue been fixed? Are we accepting PR #4906 as the fix for this bug, or only a partial fix since it limits the scope of the relative paths to within a given set of `Library`, `Bit`, and `Shape` folders? Any ideas? |
I can confirm bug as reported. |
This ticket has been migrated to GitHub as issue 6209. |
| 2021-04-28 15:23 | dubstar_04 | New Issue | |
| 2021-05-04 06:48 | dubstar_04 | Note Added: 0015647 | |
| 2021-07-25 04:09 | russ4262 | Note Added: 0015748 | |
| 2021-09-03 22:03 | russ4262 | Note Added: 0015894 | |
| 2021-09-03 22:19 | russ4262 | Assigned To | => russ4262 |
| 2021-09-03 22:19 | russ4262 | Status | new => confirmed |
| 2021-09-03 22:19 | russ4262 | Note Added: 0015898 |
