0000465FreeCADBugpublic2011-11-04 20:51
Reportertilas Assigned To
PrioritynormalSeveritytweakReproducibilityalways
Summary0000465: Sketcher: Inconsistent selection behavior
Descriptioncurrently consequent clicking on different entities performs an 'also select', whereas outside the sketcher, consequent clicking perform 'reselect'. To allow 'also' outside the sketcher one must press and hold ctrl button.
I believe that
a. the behavior must be the same everywhere.
b. the behavior outside the sketcher (reselect) is the correct one.
Jriegel
2011-11-04 20:51
administrator   ~0001238
The "greedy" selection in the Sketch edit is IMO the better behavior for that kind of workflow. Its on intention and not a bug!
I would like to see such matter of taste is issued and disused on the forum.
Its not a good idea to declare everything you dislike as a bug!
2011-11-02 19:43 tilas New Issue
2011-11-03 17:09 logari81 Summary Inconsistent selection behavior in Sketcher => Sketcher: Inconsistent selection behavior
2011-11-04 20:51 Jriegel Note Added: 0001238
2011-11-04 20:51 Jriegel Status new => closed
2011-11-04 20:51 Jriegel Resolution open => won't fix
