| 0004687 | TechDraw | Bug | public | 2021-06-19 10:34 | 2022-02-02 16:58 |
| Reporter | run_the_race | Assigned To | wandererfan | ||
| Platform | FreeCAD 0.19 | OS | Windows | OS Version | 2004 |
| Summary | 0004687: Regression: TechDraw 3D Dimensions no longer ISO Spec | ||||
| Description | This Wiki post shows 3D dimensions corrected formated in the iso spec (using 0.18): https://wiki.freecadweb.org/Basic_TechDraw_Tutorial ![]() But this is how they actually come out in (0.19): Here are forum threads discussing the issue: https://forum.freecadweb.org/viewtopic.php?f=3&t=22014 https://forum.freecadweb.org/viewtopic.php?f=35&t=58282 | ||||
| Steps To Reproduce | 1. Add a 3D view to tech draw 2. Add a dimension | ||||
| FreeCAD Information | OS: Windows 10 Version 2004 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.24276 (Git) Build type: Release Branch: releases/FreeCAD-0-19 Hash: a88db11e0a908f6e38f92bfc5187b13ebe470438 Python version: 3.8.6+ Qt version: 5.15.1 Coin version: 4.0.1 OCC version: 7.5.0 Locale: English/United Kingdom (en_GB) | ||||
commit 4da3c21dcf allows user to specify layout of dimension and extension lines. The automatic alignment function in v0.18 was very simple minded and did not always produce the correct result. This override function provides the needed functionality. |
will not re-implement v0.18 functionality. |
| 2021-06-19 10:34 | run_the_race | New Issue | |
| 2021-06-19 10:37 | run_the_race | Description Updated | |
| 2022-02-02 16:56 | wandererfan | Note Added: 0016335 | |
| 2022-02-02 16:58 | wandererfan | Status | new => resolved |
| 2022-02-02 16:58 | wandererfan | Resolution | open => won't fix |
| 2022-02-02 16:58 | wandererfan | Note Added: 0016336 | |
| 2022-02-02 16:58 | wandererfan | Assigned To | => wandererfan |
| 2022-02-02 16:58 | wandererfan | Status | resolved => closed |
